Topic: Arduino powered ECU for diesel engines (Read 30703 times) previous topic - next topic
UnaClocker
Why use a Mega when the DUE is out now? The DUE has oodles of ram, as well as having a native CAN bus. It'd make an awesome ECM.
Oldbeaver
I once bought an engine without original ECU unit at all. So i did have choice to find original ecu or bring own solution for that, and i did choose later option.
So here is it, running fine on test bench: http://www.youtube.com/watch?v=qj0S2_57EU4&feature=player_embedded
This engine (Audi 5cylinder TDI) has Bosch VP37 injection pump on it. I had to fully reverse engineer all controlling parameters for it.
Configuration can be done over USB real time (ANSI/VT102 text-mode user interface), there is also Debugging and Monitor software written in processing which includes meters display, data logging and of cource - terminal emulator for to connect the boards UI.
More information on my website: http://dmn.kuulalaakeri.org/dmn-edc/
Very nice Project. Please continue posting yr progress.
janost
Simple answer: The ATmega chip is like $4?
rusefi
Are you still playing with all this?
I am involved with another DIY ECU project and I wonder if you have the time to help us add diesel support, at least by trying our board & code on your test engine?
guruji1
Hi is there someone who programmeda faulty ecu for motor scooter with arduino please?
Thanks
Andrew
svitky
Hi to all
the project site is down, does anybody have some schematics and the code to share?
thanks in advance
peter
