Topic: DHT11 sensor Sending data by xbee to xbee (Read 14099 times) previous topic - next topic
vmansmx5
Well after a few hours nuting it out i just about have it working but with one little problem with the reciver end here is the tx code
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
float h = dht.readHumidity();
float t = dht.readTemperature();
Serial.print("<T:");
Serial.print(t, DEC);
Serial.print(">");
delay(2000);
Serial.print("<H:");
Serial.print(h, DEC);
Serial.print(">");
delay(2000);
The Rx code
char inData[24];
byte index;
boolean started = false;
boolean ended = false;
Serial.println("Temperature & Humidity");
  while(Serial.available() > 0)
char aChar = Serial.read();
if(aChar == '<')
    started = true;
    index = 0;
    inData[index] = '\0';
else if(aChar == '>')
    ended = true;
else if(started)
    inData[index] = aChar;
    index++;
    inData[index] = ',';
  if(started && ended)
// Use the value
if(inData[0] == 'T')
   inData[0] = ' ';
   int windVal = atoi(inData);
           Serial.println(" ");
   Serial.print("Temp:");
           Serial.print(inData);
           Serial.print("C");
else if(inData[0] == 'H')
   inData[0] = ' ';
           int temp = atoi(inData);
           Serial.print("Humidity:");
           Serial.print("%");
started = false;
ended = false;
index = 0;
This is what im getting in the coms on the reviver end
Temp: :16.0000000000,C
Humidity: :42.0000000000,%
the problem is whats all the 000000000000 on the end i just want 16.00C or 42.00%
How can i fix this need help
vmansmx5
well i added the lcd to the reciver end works great but all them 0000000000 i dont get
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,21);
char inData[24];
byte index;
lcd.init();
lcd.backlight();
lcd.begin(20, 4);
lcd.setCursor(6, 1);
lcd.print("WELCOME");
delay(3000);
lcd.clear();
if(aChar == '<')
    started = true;
    index = 0;
    ended = true;
else if(started)
    index++;
// Use the value
   inData[0] = ' ';
           Serial.print("C");
           lcd.setCursor(0, 0);
           lcd.print("Temp:");
           lcd.setCursor(0, 1);
           lcd.print(inData);
           lcd.print("C");
   inData[0] = ' ';
           Serial.print("%");
           lcd.setCursor(0, 2);
           lcd.print("Humidity:");
           lcd.setCursor(0, 3);
           lcd.print(inData);
           lcd.print("%");
started = false;
ended = false;
index = 0;
vmansmx5
#2
Jul 06, 2012, 01:29 pm Last Edit: Jul 06, 2012, 01:33 pm by vmansmx5 Reason: 1
I fixd it here we go
#include "DHT.h"
#define DHTPIN 2
Serial.print("<T");
Serial.print(t);
Serial.print(">");
delay(2000);
Serial.print("<H");
Serial.print(h);
Serial.print(">");
delay(2000);
i took out the Serial.print(h, DEC);
and it works great  :)
Temp: 17.00,C
Humidity: 57.00,%
Temp: 17.00,C
Humidity: 56.00,%
Temp: 17.00,C
Humidity: 55.00,%
PaulS
For floats, the 2nd argument is the number of decimal places to print. You are telling it to print 10 decimal places.
vmansmx5
Ok is that good.
here i have the transmitter with temp sensor moisture sensor and voltage but have proplems with the moisture reading on the reciver end. im geting .00 coming up when its on 0 this so my display its a 4line lcd
Temp:        17.00 C
Humidity:   40.00 %
Moisture:    0 .00
Voltage:     5.00  V
This is the code for the TX unit
#include "DHT.h"
#define DHTPIN 2
int Sensor1 = A0;
int analogInput = A1;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000.02;
float R2 =  7399.40;
int value = 0;
int Sensor1 = analogRead(A0);
value = analogRead(analogInput);
vout = (value * 5.0) / 1024.0;
vin = vout / (R2/(R1+R2));
Serial.print("<T");
Serial.print(t);
Serial.print(">");
Serial.print("<H");
Serial.print(h);
Serial.print(">");
Serial.print("<M");
Serial.print(Sensor1);
Serial.print(">");
Serial.print("<V");
Serial.print(vin);
Serial.print(">");
delay(5000);
and the RX
#include <Wire.h>
char inData[24];
byte index;
lcd.init();
lcd.backlight();
lcd.begin(20, 4);
delay(3000);
lcd.clear();
delay(100);
  lcd.print("Temp:");
  lcd.print("Moisture:");
  lcd.print("Voltage:");
if(aChar == '<')
    started = true;
    index = 0;
    inData[index] = ' ';
    ended = true;
else if(started)
    index++;
// Use the value
   inData[0] = ' ';
           Serial.print("C");
           lcd.setCursor(11, 0);
           lcd.print(inData);
           lcd.print("C");
   inData[0] = ' ';
           Serial.print("%");
           lcd.setCursor(11, 1);
           lcd.print(inData);
           lcd.print("%");
        else if(inData[0] == 'M')
   inData[0] = ' ';
           Serial.print("Moisture:");
           lcd.setCursor(11, 2);
           lcd.print(inData);
        else if(inData[0] == 'V')
   inData[0] = ' ';
           Serial.print("Voltage:");
           Serial.print("Volts");
           lcd.setCursor(11, 3);
           lcd.print(inData);
           lcd.print("V");
started = false;
ended = false;
index = 0;
PaulS
else if(started)
    index++;
The last line, inData[index] being assigned a space, is wrong. That array element should be assigned a NULL, instead.
vmansmx5
#6
Jul 08, 2012, 04:45 am Last Edit: Jul 08, 2012, 04:49 am by vmansmx5 Reason: 1
ok i put thet bit in and it works but had to add in a line to clear the last val it stayed on the lcd
          lcd.print("     ");
           lcd.print(inData);
#include <Wire.h>
char inData[24];
byte index;
lcd.init();
lcd.backlight();
lcd.begin(20, 4);
delay(3000);
lcd.clear();
delay(100);
 lcd.print("Temp:");
if(aChar == '<')
   started = true;
   index = 0;
   ended = true;
else if(started)
   index++;
// Use the value
  inData[0] = ' ';
  int TempVal = atoi(inData);
          Serial.print("C");
          lcd.print(inData);
          lcd.setCursor(18, 0);
          lcd.print("C");
  inData[0] = ' ';
          int HumidityVal = atoi(inData);
          Serial.print("%");
          lcd.print(inData);
          lcd.setCursor(18, 1);
          lcd.print("%");
          inData[0] = ' ';
          int MoistureVal = atoi(inData);
          lcd.print("     ");
          lcd.print(inData);
  inData[0] = ' ';
          int VoltageVal = atoi(inData);
          lcd.print("          ");
          lcd.print(inData);
          lcd.setCursor(18, 3);
          lcd.print("V");
started = false;
ended = false;
index = 0;
vmansmx5
i have also been working on this code for the transmiter what im tying to do is have the reviver send a code to the transmitter then it reads it then sends the value to the reciver then the reviver displays the value then sends out the next code and so on till it gets all 4 values then it delays then dose it all again.
So what i want is the reciver to send this
send this <R> For Temp Val
wait for incoming val
then display incoming Val
send this <B> For Humidity Val
send this <C> For Soil Val
send this <D> For Volt Val
then delay for 5mins then start again
This works great if i send them out the coms using my xbee coms board
Can anyone help me with this
This is the transmitter code.
#include "DHT.h"
#define DHTPIN 2
char inData[24];
byte index;
int Sensor1 = A0;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000.02;    // !! resistance of R1 !!
float R2 =  7399.40;     // !! resistance of R2 !!
// variable to store the value
int value = 0;
if(aChar == '<')
    started = true;
    index = 0;
    ended = true;
else if(started)
    index++;
// Use the value
if(inData[0] == 'R')
           inData[0] = ' ';
   Serial.print("<T");
           Serial.print(t);
           Serial.print(">");
else if(inData[0] == 'B')
           inData[0] = ' ';
   Serial.print("<H");
           Serial.print(h);
           Serial.print(">");
        else if(inData[0] == 'C')
   inData[0] = ' ';
           Serial.print("<M");
           Serial.print(">");
        else if(inData[0] == 'D')
           inData[0] = ' ';
   Serial.print("<V");
           Serial.print(vin);
           Serial.print(">");
started = false;
ended = false;
index = 0;
vmansmx5
ok so i put on a TFT color LCD looks Great just been playing around with it here are some photos of my workbench the photos are not the best.
PaulS
So, what is the problem?
vmansmx5
#10
Jul 09, 2012, 02:29 am Last Edit: Jul 09, 2012, 02:33 am by vmansmx5 Reason: 1
Well not sure on the reciver code how to set it up like this.
i can send the  R B C D by my xbee adapter board and the transmitter sends back the values.
But how to set up the reviver part im not sure can i put in a delay that waits for incoming val then sends out the next code......
So what i want is the reciver to Run like this
PaulS
<snip>
I'm confused. What are you sending "<R>" to? What is sending data? Why does the receiver need to wait?
In my mind, the receiver should do nothing until it receives a letter command. It should then process that command, which means sending the appropriate output. There is no reason for it to delay at all.
The application that sends the letter commands should only send them once every 5 minutes.
vmansmx5
the reciver is sending <R> for temp to the transmitter then the transmitter sends back the value for the of temp
the reciver then displays the value.
then the reciver sends <B> For Humidity to the  transmitter then the transmitter sends back the value for the of temp
and so on
I tryd this but it keeps sending then out and cant get the value back delays dont work
  lcd.print("Temp:");
  Serial.print("<R>");
  Serial.print("<B>");
  Serial.print("<C>");
  Serial.print("<D>");
if(aChar == '<')
    started = true;
    index = 0;
    ended = true;
else if(started)
    index++;
// Use the value
   inData[0] = ' ';
           Serial.print("C");
           lcd.print(inData);
           lcd.print("C");
   inData[0] = ' ';
           Serial.print("%");
           lcd.print(inData);
           lcd.print("%");
   inData[0] = ' ';
           lcd.print(inData);
   inData[0] = ' ';
           lcd.print(inData);
           lcd.print("V");
started = false;
ended = false;
index = 0;
PaulS
Send a bunch of requests on every pass through loop. Then, don't wait for a response or for any data to have arrived. OK, I think I see the problem.
You need to create a blocking function, called after each request for data, that waits for a reply.
You are sending R, B, C, and D, and expecting T, H, M, and V. Why is that?
vmansmx5
Becouse i want the reciver to send out R,B,C,D to get the value back by T,H,M,V
How can this be done?
