Topic: How to detect FTDI UART connected to Arduino? (Read 3299 times) previous topic - next topic
_Leo_
Everyone,
I need a simple, effectiv and fast working solution on how to detect a FTDI UART connected to the Arduino.
Code: [Select]
Setup()
if(FTDI UART board is connected to Arduino)
do this....;
else  // (Arduino is connected to a battery only)
  do that....;
Thank you.
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
Grumpy_Mike
Well you can't.
On a normal arduino the FTDI is connected all the time, what you are asking is is that connected to a USB.
Short of sending something out and seeing if there is a responce, there is nothing you ca do to detect if it is connected.
_Leo_
I'm using a Pro mini and a FDTI breakout board (I forgot to mention that).
Would that be possible?
If not, how would an example  "sending something" code look like?
Thank you.
Leo
PaulS
Quote
Code: [Select]
Serial.print("Hey, anybody want to do my research for me?");
Grumpy_Mike
#4
Jul 18, 2012, 11:15 am Last Edit: Jul 18, 2012, 11:22 am by Grumpy_Mike Reason: 1
Quote
Code: [Select]
Serial.print("something");
This then relies on you having something at the other end that well send something back when it receives a prompt. If it has not replied in a certain amount of time then you can assume nothing is connected.
Code: [Select]
nothing = false;
long time= millis();
while(Serial.available() == 0 && nothing == false { if( (milis() - time) > timeout) nothing = true; }
// nothing = false if you have a connection and true if you do not
dxw00d
Quote
// nothing = false if you have a connection and false if you do not
Copy/Paste problem?
Grumpy_Mike
First thing in the morning brain fart problem.
_Leo_
Thanks guys.
I was hoping to avoid a solution as described above and wishing more of a method like; is any one PIN on FTDI board up or down.
Leo
pylon
You can make a special connector for your FTDI board that pulls some pin to ground when connected and program your Arduino to activate the pullups for that pin. So without the board connected you read HIGH, with the board connected it's LOW.
As this requires special hardware (the special connector) the other posters are right, that it's not possible by using only software (except if you have more than the FTDI connected like a computer that reacts to some prompt).
graynomad
You will have to add at least a little hardware. How about a pulldown resistor on the RX or DTR pin, when the FTDI cable is plugged in that should go high.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
_Leo_
Thanks again guys.
Since I want to aviod any hardware changes I found a compromise solution by using the led on the Arduino to tell me if RX and TX is ready.
That will work for now.
Leo
