You need to know 2 things for selecting the optocoupler.
1. The maximum voltage you will be switching.
2. The maximum current you will be switching.
Then you look in the data sheets, and find the optocoupler with a collector-emitter voltage and current that exceeds what you will be working with.
While I don't yet know the maximum voltage and current, I was looking at the data sheets to see if I could find the differences. First of all, there seems to be 3 different types of Optocouplers here. There are only two options on max voltages (30V and 80V), and only one lists a continuous current on the output information.
3041: NPN Transistor Output
Collector-Emitter Voltage, VCEO: 30V
Continuous Collector Current, IC: 150mA
3042: NPN Transistor Output
Continuous Collector Current, IC: None listed
3043: NPN Transistor Output
Collector-Emitter Voltage, VCEO: 80V
3044: NPN Darlington Transistor Output
3045: Silicon NPN Darlington Phototransistor Output
My assumption at this point is that I don't need a Darlington pair transister, and should focus on the first 3 options. Am I understanding correctly?
Am I looking at the right voltage figure on the data sheet? What about "collector current"?
Thanks! I appreciate the time. I want to understand why I need what...rather than just buying parts from someone else's parts list.
