Topic: how to make three-dimensional objects completely touch sensitive (Read 11427 times) previous topic - next topic
rbosamiya9
You can easily make paint from graphite or else the easier option will be to take out carbon from AA or AAA battery. Then mix some water and obtain the consistency like paint by stirring it properly, Then paint it on a surface whatever you want to make touch sensitive.
Connect this sensitive surface to A0 or any analog pin of arduino   and upload the following code
Code: [Select]
#include <ADCTouch.h>
int ref0;     //reference values to remove offset
  // No pins to setup, pins can still be used regularly, although it will affect readings
  ref0 = ADCTouch.read(A0, 500);    //create reference values to
  int value0 = ADCTouch.read(A0);   //no second parameter
  value0 -= ref0;       //remove offset
  Serial.print(value0 > 40);    //send (boolean) pressed or not pressed
  Serial.print("\t");           //use if(value > threshold) to get the state of a button
Serial.print(value0);             //send actual reading
  Serial.print("\t");
  Serial.println(value1);
  delay(100);
Here if value0 will be greater than 40 it means that touch is detected.
you can use this code according to your need.
You can install this library from arduino library manager library.
Thank You
