Topic: MEGA Olympic-New way of using MEGA (Read 6880 times) previous topic - next topic
jimbo.we
Jul 26, 2012, 07:00 pm Last Edit: Jul 27, 2012, 12:35 pm by jimbo.we Reason: 1
Aruidno MEGA is amazing, but when I use it , I always think that there so many I/Os I can not use with my shields. One day, a thought come into my mind: I can divide the 4 UARTs and 16 analog inputs into 4 units, then each unit will have 4 analog inputs, one UART and I2Cs.
Finally after a few days, I come up with a complete idea: break out MEGA into 4 UNO R3 interfaces, each unit has one UART, 2 I2Cs and 4 analog inputs. Two of the 4 units have the same SPI interface(Unit 1 and Unit 3), and the other two units have the same ICSP of ATmega2560 (datasheet), and I name it - Mega Olympic, which not only can expand vertically but also can extend laterally, and  almost compatible with all the shields designed for the Arduino UNO, Duemilanove or Diecimila and their clones.
For more information please refer to http://www.geekonfire.com/wiki/index.php?title=Geekduino_Mega_Olympic(2560)
Hardware Diagram
New way of Installation
Coding Badly
I hate to rain on your parade but if the Olympic Committee lawyers spot that logo on your board they ... ur ... well ... this should give you an idea of what to expect...
https://www.google.com/search?q=olympic+knitting+controversy
plastygrove
I think that's one of the sexiest adaptations of an Arduino board that I've seen so far. I haven't used the Mega because I don't think my projects have pushed the Uno to it's limits yet, but I finally see a brilliant use for it. Part design, part engineering, wholly amazing. :)
Well, a controversy for the Arduino community wouldn't be bad. Think of all the free publicity and recognition the knitting folk are getting for their passion. We'll start our own petition and letters :)
Tom Carpenter
Quick suggestion. The SPI going into the lower right corner uses the same SS pin as the one on the top left. If you used a different IO pin for the bottom one, it would be possible to use both at the same time without having a jumper wire on one of the sheilds.
And yeah, the name breaches intellectual property laws on the olympic trademark.
~Tom~
CrossRoads
I think that is awesome.
Kind of like taking the JeeNode 'port' idea up a notch further.
MichaelMeissner
#5
Jul 26, 2012, 10:11 pm Last Edit: Jul 26, 2012, 10:13 pm by MichaelMeissner Reason: 1
Neat idea and layout.  I would suggest if you can, put some separation between the four quarter planes, to allow for using multiple shields that overhang somewhat over the UNO pin layout.  In your photo, it looks like the shields at the upper left (ethernet) and lower right (display) might not work if they were side by side.  I wonder if you might have power problems if you are trying to use four full shields at the same time.
jimbo.we
#6
Jul 27, 2012, 04:04 am Last Edit: Jul 27, 2012, 09:11 am by jimbo.we Reason: 1
I have thought about the legal issues. But I really want to put some Olympic elements into my design, so I only make a few dozens PCB, so that my idea of MEGA Olympic can come to life.
jimbo.we
I have thought of the separation between the 4 units. I think the separation is enough, the shields at the upper left (ethernet) and lower right (display) do work  side by side, the illusion you see may cause by the angle of taking picture.
Power consumption is based on the shields you install. Most of the shields for arduino is low power consumption, so driving four shields hardly will be problem.
keeper63
I'm not absolutely certain, but I believe the logo of the Olympics is a registered trademark in WIPO signatory countries (you may want to think carefully about this, and possibly consult a lawyer).
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
dxw00d
It is indeed. Currently LOCOG (London Organising Committee of the Olympic Games) is chasing people down in the UK. It has been mentioned in one of the other identical threads.
Personally, being in the UK (but outside of London), I am already totally fed up of the Olympics, given that it has cost us over £9billion ($14 billion), when hospitals and schools are being closed due to lack of money, so something with the Olympic logos splattered over it would put me right off buying.
jimbo.we
I have thought about the legal issues. But I really want to put some Olympic elements into my design. So I make a few dozens PCB, so that my idea of MEGA Olympic can come to life.
dxw00d
I know. It's the same answer you gave on one of the other cross-posted threads. Doesn't change the fact that if you attempt to market them, and are discovered, you will be in trouble. Both the rings symbol and the word Olympic are legally protected.
http://www.london2012.com/documents/brand-guidelines/guide-to-protected-games-marks.pdf
AWOL
OP: I have merged two of your duplicate threads that had responses and deleted the third that didn't.
DO NOT CROSS-POST - IT WASTES TIME.
nickgammon
... and I name it - Mega Oliymic, ...
You seem to have trouble remembering its name.
As does your linked web page:
Quote
Quad-Core Arduino? No, It is Geekduino MEGA Olympic! ... The Mega Oliymic has 4 UNO R3 interfaces, ...
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
AWOL
I suppose that's one way of circumventing copyright.
