Topic: Arduino library for WTV020-SD-16P audio module (Read 354845 times) previous topic - next topic
ardianet
#270
Mar 29, 2015, 07:25 pm Last Edit: Mar 29, 2015, 07:27 pm by ardianet
First of all, thanks for The-Rebel-Agent for writing up the library. I think most people using WTV020 with Arduino are using the library, including me. :)
Secondly, I want to share my experience with the module :
At first try my WTV020 (marked : WTV020M01, V1.00, 2012.01.12) didn't play or outputing any sound. Read from previous post that several WTV020 module playing only .wav file. So I took the .wav file from the 1st Medal-Of-Honor game.. still no sound played. So I re-check the wiring, and whallaa.. my jumper cable that connect to ground pin is a bit loss. After changing the cable, the module start playing choppy sound..  I try to convert it to .ad4... and now the module is playing the sound.
I'm using "generic" V-Gen 2GB Card. Here's the step :
- Rechecking the wires.
- Formatting my SDCARD with : SDFormatter (turn into FAT (only) Format)
- Coverting the .mp3 files to ad4 with : 4D-SOMO-TOOL , renamed the file with 000x.ad4
- Upload the exact code at the first page of this thread, hear the sounds.
Third, the problems :
1. I need to add delay(10) between played files to have complete sound. Is there a way to play the files  in sequent without using delay() command ? (using millis perhaps ??)
2. There are "Click" sound on every start & end of sound played. Any info how to remove that click sound ? is it because of the .mp3 to .ad4 convert process ? some say adding coupling transistor could vanishing the click sound, is it true ?
Regards
mweber
All those who are having difficulties, check out this wiki:
http://matthew-morris.com/wiki/index.php?title=Wtv020-SD-16P#Picaxe_Serial_Mode_Notes
I found it extremely useful.  In particular the timing modifications for the library also worked for me:
Give it 750msec after reset (not 300msec as in the spec sheet).  Library line 37.
Also, the BUSY line doesn't respond immediately, leading to playVoice starting, then stopping and restarting, after a reset.  The change to 50msec in line 94 fixes that.
I also found that calling
wtv020sd16p.stopVoice()
after each playback (synchronous or asynchronous) is necessary for the next playback to reliably start.
My module says V1.00.  I am running it with a SanDisk 1 GB card.
I did not have to connect the SD card pin 6 to Ground.
At first, it didn't seem to be working in the stand-alone playback mode.  Briefly shorting the NEXT or PREV key seemingly unstuck it.  Maybe it has to do with the module remembering the file (voice) it previously played or something weird being in there as factory default.
Good luck,
black_angel1
Hi all
I bought WTV020-SD-16P U-Disk Audio Player SD Card MP3 Voice Module
from one china web
i have kingstone 2GB Micro sd card
and its not working
the module is
WTV020M01 V1.00
2012.01.12
i was trying 5V and 3.3V same result
i conected the module to arduino mega like
i connected earphones to it and i can hear some noise by pushing the next / previous button
and some noise like is searching on the card
I think the problem is the sd card but maybe i am wrong
i dont have another sd card to compare
i just want to know if other people which have problem with the card have same experience
the SD card is formated to FAT(FAT16) and also tried to change the size to 1GB
sorry for my English
ardianet
Hi all
from one china web
and its not working
the module is
WTV020M01 V1.00
2012.01.12
I'm using MEGA 2560 too. But now I'm using it with (DIY) WTV020 shield on UNO.
My WTV020 is connected without Prev / Next Button & LED.
Just connect the (WTV020) : Pin 1 (Reset), Pin 4 & 5 (Speaker out), Pin 7 (Clock), Pin 8 (Ground), Pin 10 (Data), Pin 15 (Busy), Pin 16 (Vcc, 3.3V) to Arduino.
If there's no sound played, first re-check the wires, always re-check the wires.  ;)
For hearing the sound played I'm using 3-feet-female-connector (which 2 feet connected to pin 4 & 5, & 1 feet to GND).
Secondly check the file type (.wav / .ad4) & name (use 4-digit-3-type, ex. : 0001.ad4, 0002.ad4, 0510.ad4).
You could read my post at #270 for other supporting tools.
Regards
jthefreak
Hi kiwisincebirth,
Sorry for the late reply. I did indeed find the missing ground as you suggested. I soldered the wire and at least I can hear music this time but not the complete song. It stops after approx. 20 seconds of starting playing the song. It partially works this way  for the following memory cards: one 2G Sandisk and one 2G Kingston cards. It does not work for another 2G sandisk card. They are all being formatted the same way and they all also use the same files. I have no idea what the problem is. I guess I would have to look for a similar module that plays some audio for Arduino.
thank you.
Try reducing the level of your music before converting it to .ad4. I had the same problem, and believe I was overloading the very small amp in the wtv - I noticed the volume was higher in my music, compared to the example songs. I reduced the level in Audacity, and reconverted and it played fine.
Dr_Ugi
#275
Apr 24, 2015, 04:17 pm Last Edit: Apr 25, 2015, 10:55 am by Dr_Ugi
Hello all
Firstly:  A big "thank you" to the-rebel-agent and all who have contributed to this thread.  I have used and referred to many of the posts to make progress with these little devices so thanks to you all.
I have been putting together a small kids' project with these so I have had to find a system that works reliably rather than just as a one-off.  What I have found is as follows:
  • Windows formatter does not work - I needed to use SD formatter
  • Formatting with SD formatter 16-bit FAT full overwrite is slow but works every time
  • I have tried a dozen or so small SD cards (1-2 GB), all branded SanDisk.  They do not all behave the same.
  • All work but some require pin-6 shorted to Gnd.  Some don't need this
  • I can accurately predict which cards need the pin-6 short by looking at them
  • If an SD card is flat on the back then it will need the pin-6 short to gnd
  • If it has a small raised rectangle visible on the back (where the black rectangle is here: http://commons.wikimedia.org/wiki/File:Micro_SD_card_%28Nokia%29_back.jpg) then it will not need the pin-6 short.
I have been using a v1.0 board at 3v3 for this testing.  Although I have largely tested SanDisk cards, I strongly suspect that the differing behavior suggests some to be fake so it is likely that other cards will behave the same way.  I will test some more shortly and report if I find any difference.
Cheers
Ugi
Update: Having tested several more cards, the same rule applies - unbranded flat-back cards all work but require P6-gnd.  The only exception so far is a genuine Samsung which was flat-back but worked without the ground short. Ugi
sharbon
kolban
Is there a GitHub or other open source repository for the library?  I understand it is available for download on the 1st page of this thread but would like to know if I am using the latest and greatest and GitHub is a great place for learning that kind of thing.
nahueldiaz360
hello friend .. me you could leave a small example of the structure using the Arduino program in conjunction with WTV020 .. thanks greetings
joho65
Hello!
First, I am German, so have only Tech-Speak English.
As I want to play with this (for a speaking Clock), I made any Investigations.
To avoid any Problems with Powersource, I made an reverse Engeneering on this Chip.
I want to know, how this Things go together. And I was share this to the Community.
On the PCB is a Place for an 5V to 3,3V Linearregulator, but not on Board.
I will take an MIC5205. Then You can drive this with 5V. I will do so.
The Transistor left make GND for the SD-Card, but only, when the BUSY -Signal is high!
That makes Sin for Energymanagement (Battery Live). But it can too have
Influences for the behavior of the SD-Card (Hard Reset). This can be useful for
the Timings in the Library.
greetings Jo
Botyard
Is this the proper way to use the code from the library to test the playback of audio track 0000.ad4...
Code: [Select]
  //Plays synchronously an audio file. Busy pin is used for this method.
    wtv020sd16p.playVoice(0);
It seems I have everything correct but my speaker is only outputting a strange sine wave type beep with a half second gap between playing, and the sound is very, very low. Without having to order a bunch of SD cards to test, does anyone know what's going on here?
webjoe
I was wondering if this module can simultaneously play sounds
(eg 5 buttons with different sounds to be performed at the time we want,
as a simulation program of a multi track where a sound would play together with other
the ways of playing audio I've ever done with volume, Next, Previous, etc.
Tanks
Jocke73
also for me the fix to connect pin 6 to GND worked. The module now works fine with my no-name 2GB SD-card.
/Jocke
Bamdad
hi
can anyone give me help?
I want to convert my mp3 files to ad4 for this thing... how can I???
ardianet
hi
You can use 4D-SOMO-TOOL.
Download it here :
http://www.4dsystems.com.au/downloads/Software/SOMO-14D%20Audio%20Converter/4D-SOMO-Tool.zip
