Topic: [SOLVED] Arduino Duemilanove - Ethernet Shield 1.1 - LocalIP() = 0.0.0.0 (Read 6190 times) previous topic - next topic
iisfaq
I have never done anything with Arduino and Ethernet.
I have plugged in an ethernet shield and my network is on 192.168.2.x
The cable works fine issuing a DHCP address to my laptop.
But my arduino returns 0.0.0.0 in the setup routine (Ethernet.LocalIP()) and does not answer on the configured IP Address. I have chosen some random Mac Addresses incase of unknown conflict.
The Green LED on the Ethernet plug on the shield is lit. And the orange led is flickering so there is life. Also the power led on the ethernet board is lit.
I am using Arduino IDE 1.0.1
I am really not sure what to do?
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0xDD, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE };
IPAddress ip(192,168,2, 197);
EthernetServer server(80);
Serial.println("Ethernet Begin");
  Ethernet.begin(mac, ip);
Serial.println("server");
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
 /* add main program code here */
// Is there any client requests?
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv=\"refresh\" content=\"5\">");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("<br />");
client.println("</html>");
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
Any help appreciated.
Chris
PaulS
What is the Arduino with Ethernet shield connected to? Have you told that device about the Arduino's use of that IP address?
SurferTim
Don't know if you found the problem, but have you tried the DhcpAddressPrinter sketch in the ethernet examples?
Do you have a microSD card in the shield's slot?
iisfaq
Thanks for your advise - I did some more searching and found that I am using a cheap clone card with a Microchip ENC28J60 chip?
I think that this is not as powerfull as the new 5100 versions.
I found a library here http://www.nuelectronics.com/estore/index.php?main_page=product_info&cPath=1&products_id=4 which works.
Thanks again - I have now purchased a new shield from EBAY - it doesn't look like the latest on Arduino site but it uses the 5100 chip.
Chris
Kostli
Chris
Could you update the link of the library which works with the ENC28J60 chip, because this link that you have already put on here does not work anymore.
Thank you!
