Topic: easyvr speech synthesis setup (Read 2456 times) previous topic - next topic
stargazer2050
Aug 09, 2012, 01:34 pm Last Edit: Aug 09, 2012, 02:36 pm by stargazer2050 Reason: 1
easyvr shield
have speech recognition working
have built and uploaded sound table and is working
need commands to run speech synthesis
  is this the command?  easyvr.playSound(1, EasyVR::VOL_FULL);
also need to know how and what to #include.
 i've tried #include "Pinghead.h"  and placed a copy of it into the easyvr library
  am getting ERROR   'far' does not name a type
PaulS
Quote
In what? For what purposes?
Quote
I'm sure that there was a lot more to that error message than that AND the compiler got to see your code.
If we can't, I suggest you look at the code at the line number, listed in the real error message, in the file referenced, and fix the problem.
stargazer2050
#2
Aug 09, 2012, 02:33 pm Last Edit: Aug 09, 2012, 02:40 pm by stargazer2050 Reason: 1
hi PaulS
in what? what purpose?  not sure what this means or what you need to know, i'll get it for you though.
This is the PINGHEAD.H  file  (not sure why they capitalize it (i may need to also?))
// external declaration of sound table:
extern far cdata SNDTBL_PINGHEAD;
// external declarations of addresses of sounds for direct access:
extern far cdata SX_yes_master;
extern far cdata SX_you_talkin_to_me;
// constants defining sounds as entries in the sound table:
#define SND_yes_master          1
#define SND_you_talkin_to_me    2
i'm getting 3 error messages
   arduino/libraries/easyvr/pinghead.h:3: error: 'far' does not name a type
   arduino/libraries/easyvr/pinghead.h:7: error: 'far' does not name a type
   arduino/libraries/easyvr/pinghead.h:8: error: 'far' does not name a type
no line number visible
would posting all code help?
PaulS
Quote
You asked what you needed to include, and how to do it. In order to answer that, we need to know what you are wanting to include things in, and what you want to include stuff for.
For instance, if you have an Arduino with an Ethernet shield, and you want it to act as a server, then you need a sketch, and you need to include Ethernet.h.
Without knowing what you are trying to do, it's really difficult to tell you what to include.
Where did you get the pinghead.h file?
stargazer2050
you helped!!! thankyou thankyou
it works.  its an arduino uno with easyvr, sound recognition with sound synthesis
i needed to #define each sound byte, i thought that was done in the soundfile.h, i guess i had to do it
thanks paul again.
