Topic: Arduino mega 2560 r3 + em-408 + gps shield (Read 5757 times) previous topic - next topic
numb3rs295
Aug 13, 2012, 06:48 am Last Edit: Aug 22, 2012, 04:30 am by Nick Gammon Reason: 1
Hi
I've tried the example code given in TinyGps library (test_with_gps), but seems like the output in serial monitor only shows stars instead of values. anyone know how to solve it? here is the code that I used:
Code: [Select]
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
  It requires the use of SoftwareSerial, and assumes that you have a
  4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial nss(3, 4);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
 nss.begin(4800);
 Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
 Serial.println("by Mikal Hart");
 Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
 Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
 Serial.println("          (deg)    (deg)     Age                        Age  (m)     --- from GPS ----  ---- to London  ----  RX    RX        Fail");
 Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
 bool newdata = false;
 unsigned long start = millis();
 // Every second we print an update
 while (millis() - start < 1000)
   if (feedgps())
     newdata = true;
 gpsdump(gps);
 float flat, flon;
 unsigned long age, date, time, chars = 0;
 unsigned short sentences = 0, failed = 0;
 static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
 print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
 print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
 gps.f_get_position(&flat, &flon, &age);
 print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
 print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
 print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
 print_date(gps);
 print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
 print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
 print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
 print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
 print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
 print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
 print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
 gps.stats(&chars, &sentences, &failed);
 print_int(chars, 0xFFFFFFFF, 6);
 print_int(sentences, 0xFFFFFFFF, 10);
 print_int(failed, 0xFFFFFFFF, 9);
 char sz[32];
 if (val == invalid)
   strcpy(sz, "*******");
   sprintf(sz, "%ld", val);
 sz[len] = 0;
 for (int i=strlen(sz); i<len; ++i)
   sz[i] = ' ';
 if (len > 0)
   sz[len-1] = ' ';
 Serial.print(sz);
 feedgps();
 char sz[32];
 if (val == invalid)
   sz[len] = 0;
       if (len > 0)
         sz[len-1] = ' ';
   for (int i=7; i<len; ++i)
       sz[i] = ' ';
   Serial.print(sz);
   Serial.print(val, prec);
   int vi = abs((int)val);
   int flen = prec + (val < 0.0 ? 2 : 1);
   flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
   for (int i=flen; i<len; ++i)
     Serial.print(" ");
 feedgps();
 int year;
 byte month, day, hour, minute, second, hundredths;
 unsigned long age;
 gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
 if (age == TinyGPS::GPS_INVALID_AGE)
   Serial.print("*******    *******    ");
   char sz[32];
   sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
       month, day, year, hour, minute, second);
   Serial.print(sz);
 feedgps();
 int slen = strlen(str);
 for (int i=0; i<len; ++i)
   Serial.print(i<slen ? str[i] : ' ');
 feedgps();
 while (nss.available())
   if (gps.encode(nss.read()))
     return true;
 return false;
Moderator edit: [code] ... [/code] tags added. (Nick Gammon)
johnwasser
Could it be that your GPS has not been operating outdoors long enough to get an ephemeris download?  Until it gets position data from the satellites it can't determine your location.
Try this sketch to see what your GPS is saying.  If you don't get recognizable NEMA messages then something is wrong (baud rate, settings, etc.)
Code: [Select]
  nss.begin(4800);
   if (nss.available())
       Serial.write(nss.read());
   if (Serial.available())
       nss.write(Serial.read());
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
numb3rs295
nothing shows up..i'm very new at this, and do not know what's going wrong
johnwasser
So your GPS module is not sending.
What exact GPS module are you using?  How is it wired?
numb3rs295
i'm using em-408 gps : https://www.sparkfun.com/products/8234
connected to gps shield : https://www.sparkfun.com/products/10710?
and the gps shield is connected to arduino mega 2560 r3 : https://www.sparkfun.com/products/11061
johnwasser
Is the switch on the shield set to DLINE, not UART?
numb3rs295
#6
Aug 21, 2012, 05:42 am Last Edit: Aug 21, 2012, 06:11 am by numb3rs295 Reason: 1
set at DLINE mode..
however, i found another method, which used serial instead od softwareserial. i used this tutorial, since they used quite similar parts as mine : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1283009227
however, what i didn't understand is whether to put in DLINE or UART mode, since serial used UART ports.
From my understanding, when uploading the code, used DLINE, and after that switch off the gps shield, and then change to UART, and then switch on the gps shield..
but when i change to UART, nothing shows in the serial monitor..
i've already desolder the jumper, and connect tx and rx pins to pin 15 and 14 at arduino, respectively
this is how i connect them..
numb3rs295
UPDATED : When I changed the configuration (shown below), the serial monitor is working when run in UART mode, but still didn't get any data. At least it shows some words unlike before. So i reckon maybe i didn't get any signal because of the connection? any ideas?
numb3rs295
or is it because of power supply?? i just use USB to computer as power supply..
i didn't know what's going wrong right know..i've tried every possible solution..
nickgammon
Can you be a bit clearer about what is connected to what? And post your current sketch inside code tags please? Judging by the Sparkfun site you need to be in DLINE mode and then can choose where to connect the pins.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
numb3rs295
This is my current sketch
Code: [Select]
  6-8-10
  Aaron Weiss
  SparkFun Electronics
  Example GPS Parser based off of arduiniana.org TinyGPS examples.
  Parses NMEA sentences from an EM406 running at 4800bps into readable
  values for latitude, longitude, elevation, date, time, course, and
  speed.
  For the SparkFun GPS Shield. Make sure the switch is set to DLINE.
  Once you get your longitude and latitude you can paste your
  coordinates from the terminal window into Google Maps. Here is the
  link for SparkFun's location.
  http://maps.google.com/maps?q=40.06477,+-105.20997
  Uses the NewSoftSerial library for serial communication with your GPS,
  so connect your GPS TX and RX pin to any digital pin on the Arduino,
  just be sure to define which pins you are using on the Arduino to
  communicate with the GPS module.
// In order for this sketch to work, you will need to download
// NewSoftSerial and TinyGPS libraries from arduiniana.org and put them
// into the hardware->libraries folder in your ardiuno directory.
// Here are the lines of code that point to those libraries.
// 28/08/2010
// I could not get the NewSoftSerial Drivers to work
// on my Arduino Mega with the Sparkfun GPS shield.
// I desoldered the 2 jumpers, then jumpered the GPS's Rx to Pin 14, Tx to Pin 15
// This is UART3
// As PaulS pointed out, why use soft serial on a board with 4 UART's?
//Set this value equal to the baud rate of your GPS
#define GPSBAUD 4800
// Create an instance of the TinyGPS object
TinyGPS gps;
// This is where you declare prototypes for the functions that will be
// using the TinyGPS library.
void getgps(TinyGPS &gps);
// In the setup function, you need to initialize two serial ports; the
// standard hardware serial port (Serial()) to communicate with your
// terminal program and another hardware serial port (Serial3()) for your
// GPS.
  // This is the serial rate for your terminal program. It must be this
  // fast because we need to print everything before a new sentence
  // comes in. If you slow it down, the messages might not be valid and
  // you will likely get checksum errors.
  //Sets baud rate of your GPS
  Serial3.begin(GPSBAUD);
  Serial.println("");
  Serial.println("GPS Shield QuickStart Example Sketch v12.u");
  Serial.println("       ...waiting for lock...           ");
  Serial.println("");
// This is the main loop of the code. All it does is check for data on
// the RX pin of the ardiuno, makes sure the data is valid NMEA sentences,
// then jumps to the getgps() function.
  while(Serial3.available())     // While there is data on the RX pin...
      int c = Serial3.read();    // load the data into a variable...
      if(gps.encode(c))      // if there is a new valid sentence...
        getgps(gps);         // then grab the data.
// The getgps function will get and print the values we want.
  // To get all of the data into varialbes that you can use in your code,
  // all you need to do is define variables and query the object for the
  // data. To see the complete list of functions see keywords.txt file in
  // the TinyGPS and NewSoftSerial libs.
  // Define the variables that will be used
  float latitude, longitude;
  // Then call this function
  gps.f_get_position(&latitude, &longitude);
  // You can now print variables latitude and longitude
  Serial.print("Lat/Long: ");
  Serial.print(latitude,5);
  Serial.print(", ");
  Serial.println(longitude,5);
  // Same goes for date and time
  int year;
  gps.crack_datetime(&year,&month,&day,&hour,&minute,&second,&hundredths);
  // Print data and time
  Serial.print("Date: "); Serial.print(month, DEC); Serial.print("/");
  Serial.print(day, DEC); Serial.print("/"); Serial.print(year);
  Serial.print("  Time: "); Serial.print(hour, DEC); Serial.print(":");
  Serial.print(minute, DEC); Serial.print(":"); Serial.print(second, DEC);
  Serial.print("."); Serial.println(hundredths, DEC);
  //Since month, day, hour, minute, second, and hundr
  // Here you can print the altitude and course values directly since
  // there is only one value for the function
  Serial.print("Altitude (meters): "); Serial.println(gps.f_altitude());
  // Same goes for course
  Serial.print("Course (degrees): "); Serial.println(gps.f_course());
  // And same goes for speed
  Serial.print("Speed(kmph): "); Serial.println(gps.f_speed_kmph());
  // Here you can print statistics on the sentences.
  unsigned long chars;
  unsigned short sentences, failed_checksum;
  gps.stats(&chars, &sentences, &failed_checksum);
  //Serial.print("Failed Checksums: ");Serial.print(failed_checksum);
  //Serial.println(); Serial.println();
And this is the connection..i've identified it with different colours, which means each colour is matched with the same colour at other part..
numb3rs295
What is it mean by "These jumpers, when disabled (solder removed), will disconnect the GPS communication lines (TX and RX) from the Arduino. This allows for the user to connect any digital line to the GPS communication lines. To use, simply disconnect the jumpers, then wire the TX and RX labeled pins on the shield to any one of the digital pins 2-13 on the shield." from : http://www.sparkfun.com/tutorials/173
Because I just de-solder the jumper, and then connect the gps shield with arduino just like what I show before. But when I read the above statement 2-3 times, I sense something wrong with my method
johnwasser
There is a switch.  When set to UART the RX and TX lines of the GPS are connected to D0 and D1.  When set to DLINE the RX and TX lines of the GPS go through solder jumpers to D2 and D3.  If you want to use pins other than D2 and D3 you have to switch to DLINE, remove the solder jumpers, AND ADD WIRES FROM THE GPS SIDE OF THE JUMPERS TO THE DATA PINS OF YOUR CHOICE.
cyberteque
