Topic: Ethernet shield not connecting to the Webserver - new to Arduino (Read 6786 times) previous topic - next topic
venardino
Hi all:
I am new to Arduino. Needed some help on connecting to the Webserver and being able to e-mail based on a PHP script. I am using a standard script borrowed from the internet.
Here is my setup:
1. Arduino Uno R3
2. Ethernet Shield R3
3. Mac OS X 10.7.2
4. Arduino IDE 1.0.1
I have posted the code I am using, the corresponding output on the serial monitor and the PHP 'test.php' file content.
Appreciate your help in fixing this or some light on what is that I am missing here fundamentally.
Code
Code: [Select]
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 6 }; //my router IP
byte server[] = {31, 170, 160, 99}; // My webserver IP
EthernetClient client;
  Ethernet.begin(mac, ip);
[size=10pt][size=10pt][/size][/size]  delay(1000);
  Serial.println("connecting...");
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.print("GET /test.php HTTP/1.0");
    client.println();
    Serial.println("Sent the http request");
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    for(;;)
Begin Output
connected
connecting...
connected
HTTP/1.1 408 Request Time-out
Date: Sun, 26 Aug 2012 13:43:17 GMT
Server: Apache
Content-Length: 223
Connection: close
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>408 Request Time-out</title>
</head><body>
<h1>Request Time-out</h1>
<p>Server timeout waiting for the HTTP request from the client.</p>
</body></html>
disconnecting.
******* End Output ***********
test.php file
<?php
  echo("<p> A sample string as test message</p>");
SurferTim
You are missing a CR/LF in your code. You must send a blank line to let the server know you are finished sending the request header. Try this instead.
Code: [Select]
    client.println("GET /test.php HTTP/1.0\r\n");
venardino
Hi SurferTim:
Thank you for a quick response. I did try your suggestion and here is the output. Please validate and let me know if there is anything still missing. Appreciate that.
connecting...
connected
HTTP/1.1 302 Found
Date: Sun, 26 Aug 2012 14:09:07 GMT
Server: Apache
Content-Length: 216
Connection: close
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://error404.000webhost.com/?">here</a>.</p>
</body></html>
disconnecting.
SurferTim
#3
Aug 26, 2012, 04:16 pm Last Edit: Aug 26, 2012, 04:18 pm by SurferTim Reason: 1
I will guess that is a virtual hosting web server. It is redirecting you to a error 404 (file not found) page. If that is the case, then you will need to send the Host parameter also. Like this:
Code: [Select]
client.println("GET /test.php HTTP/1.0");
client.println("Host: www.mydomain.com"\r\n);
Replace www.mydomain.com with your domain name. Note the double CR/LF is after the Host now.
edit: This is a thread that should be in networking. I expect we will be moved there.
venardino
Yes, it is a virtual hosting webserver. Tried your suggestion, still the same error.
Code: [Select]
client.println("Host: http://venard.hostzi.com\r\n");
dxw00d
SurferTim's example didn't include 'http://' for the host.
Yours:
Code: [Select]
SurferTim's:
Code: [Select]
venardino
Hi dxw00d:
Thank you for your observation. I did try SurferTim's suggestion and below is the outcome
1. Using this line in the code, I got the following compilation error (in red), hence had to include it within the quotes which works fine. Please let me know if that is correct or am I missing something.
sketch_aug24c:25: error: stray '\' in program
sketch_aug24c.cpp: In function 'void setup()':
sketch_aug24c:25: error: expected `)' before 'r'
2. I tried both the following and obtained same results
client.println("Host: www.venard.hostzi.com\r\n");
SurferTim
You are getting close! You have tried all but the correct combination.
Code: [Select]
client.println("Host: venard.hostzi.com\r\n");
edit: I moved the double quote. I did not notice that until I checked it.
dxw00d
Quote
I didn't spot that either.
venardino
Hi SureferTim:
I did try with the suggested code but the result is the same
Code: [Select]
connecting...
connected
HTTP/1.1 302 Found
Date: Sun, 26 Aug 2012 15:13:14 GMT
Server: Apache
Content-Length: 216
Connection: close
<html><head>
</head><body>
<h1>Found</h1>
</body></html>
disconnecting.
SurferTim
OK. Maybe it won't take HTTP/1.0. It keeps responding with HTTP/1.1, so let's try that.
Code: [Select]
client.println("GET /test.php HTTP/1.1");
client.println("Host: venard.hostzi.com");
client.println("Connection: close\r\n");
SurferTim
My bad. Always check the simple stuff first. Are you using this ip for the server?
Code: [Select]
I show your domain hosted at this ip
Code: [Select]
byte server[] = {31, 170, 161, 36}; // My webserver IP
I used nslookup to find your ip.
venardino
1. What you said is correct, i.e the hostname is resolving to a different IP {31, 170, 161, 36} than what I am currently using which is {31, 170, 160, 99}. However, I did try that earlier and got the same response from both the IPs.
2. With HTTP/1.1 here is the response.
Code: [Select]
client.print("GET /test.php HTTP/1.1");
connecting...
connected
HTTP/1.1 400 Bad Request
Date: Sun, 26 Aug 2012 15:42:30 GMT
Server: Apache
Content-Length: 226
Connection: close
<html><head>
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.<br />
</p>
</body></html>
disconnecting.
3. With HTTP/1.0 here is the response.
Code: [Select]
connecting...
connected
HTTP/1.1 302 Found
Date: Sun, 26 Aug 2012 15:43:35 GMT
Server: Apache
Content-Length: 216
Connection: close
<html><head>
</head><body>
<h1>Found</h1>
</body></html>
disconnecting.
SurferTim
I used this server:
Code: [Select]
with this request
Code: [Select]
...and it returned, among other things, "A sample string as test message". Is that what it is supposed to say? My web browser says that is correct.
venardino
Hi ServerTim:
Great! That worked for me too.
Not sure what the problem was so far. Did you do some magic?  :). It will be nice if you could share what could've gone wrong and how did it get addressed/fixed finally. I guess one of the factors being the IP address set to what it actually resolved to. The one I've used {31, 170, 160, 99} was given to me by the hosting provider.
Appreciate all the help and persistence all through till it worked.
Thanks and regards.
Here is the output at my end
connecting...
connected
HTTP/1.1 200 OK
Date: Sun, 26 Aug 2012 16:14:42 GMT
Server: Apache
X-Powered-By: PHP/5.2.17
Content-Length: 193
Connection: close
<!-- Hosting24 Analytics Code -->
<script type="text/javascript" src="http://stats.hosting24.com/count.php"></script>
<!-- End Of Analytics Code -->
disconnecting.
