Topic: CPLD and Arduino - a good mix (Read 18919 times) previous topic - next topic
pito
Aug 26, 2012, 05:22 pm Last Edit: Oct 08, 2012, 09:30 pm by pito Reason: 1
Hi, as I saw a lot of topics where the people are looking for challenging solutions where the Arduino itself cannot be fast or complex enough, I spent few hours playing with an XILINX CPLD - a free programmable hardware device, fast and cheap :)
I've got this breakout board http://www.seeedstudio.com/depot/xc9572xl-cpld-development-board-v1b-p-799.html?cPath=174 , but you may get a lot of similar ones at ebay cheap.
XC9572XL has got 34 free and 100% rootable 5V tolerant I/O pins and 72 logic cells so you can implement quite a complex wiring. As an example I've created a 32bit counter, which connected to Arduino can serve as a counter, frequency and period measurement gadget etc. The sketch is very simple - just controlling the CPLD and receiving the results (32bit counter value) and printing the results. Enclosed is the schematics of the counter (as I don't like to mess with VHDL :) ) as well.
BTW, on an ordinary breadboard it measures up to 80MHz (maybe more - I found only an 80MHz canned oscillator in my junkbox..)
p.
Code: [Select]
   Arduino and an CPLD XC9572XL - 32bit counter
   Pito 8/2012
//  http://www.seeedstudio.com/depot/xc9572xl-cpld-development-board-v1b-p-799.html?cPath=174
//           GND    |   CPLD    |
//           3V3    |  XC9572XL |
//          NCLR 22 |           |
//         NLOAD 23 |           |
//         NGATE 30 |           |
//          NCLK 31 |           |
//       NCLKOUT 32 |           |
//        SEROUT 33 |           |
#include <DigitalPin.h>
// define the control signals of the CPLD
// NGATE - it opens the counter for incoming signal
#define NGATE  4
// NCLK - input of the 32bit CPLD counter
#define NCLK 9
// NCLR - clears the CPLD's counter
#define NCLR   5
// NLOAD - loads the counter content into 32bit serial shifter
#define NLOAD  6
// NCLKOUT - clocks the serial shifter out
#define NCLKOUT 7
// SERIN - input of the data from the CPLD's SEROUT serial shifter
#define SERIN  8
 // initialize the digital pins
 fastPinMode(NGATE, OUTPUT);
 fastPinMode(NCLK, OUTPUT);
 fastPinMode(NCLR, OUTPUT);
 fastPinMode(NLOAD, OUTPUT);
 fastPinMode(NCLKOUT, OUTPUT);
 fastPinMode(SERIN, INPUT);
 Serial.println("CPLD Test Starts");
 //default signals are HIGH, active LOW
 fastDigitalWrite(NGATE, HIGH);
 fastDigitalWrite(NCLR, HIGH);
 fastDigitalWrite(NCLK, HIGH);
 fastDigitalWrite(NLOAD, HIGH);
 fastDigitalWrite(NCLKOUT, HIGH);
 Serial.println("CPLD Test Loop");
 while(1) {
 //clear the 32bit counter
 fastDigitalWrite(NCLR, LOW);
 //gate the counter input
 fastDigitalWrite(NGATE, LOW);
 //delayMicroseconds(1);
 //load the 32bit counter value into the serial shifter
 fastDigitalWrite(NLOAD, LOW);
 fastDigitalWrite(NCLKOUT, LOW);
 //read the value from CPLD's serial 32bit shifter
 int i;
 unsigned long count = 0;
 for (i=0; i<=31; i++) {
     count = count << 1;
     count = count + fastDigitalRead(SERIN);
     // clockout the shifter
 Serial.print("CPLD counter= ");
 Serial.println(count);
 delay(100);              // wait for a while
graynomad
These are nice. Every now and then I think about getting into some CPLDs but I can never really come up with an application that needs one.
Quote
I'm with you there :)
I see the dev environment is about 6Gig+ to download, won't happen in this lifetime I'm afraid, at least not until the mobile data plans triple in size for the same price.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
pito
#2
Aug 27, 2012, 12:41 pm Last Edit: Aug 27, 2012, 01:22 pm by pito Reason: 1
I did some improvements there - I've put an internal oscillator (ring oscillator) in the CPLD, which runs at ~135.27MHz. There is an additional NSEL pin (selects internal/external oscillator as the source of the signal for the counter, you may gate the sources with NGATE) see below.
When running (atmega @ 16MHZ) and counter is sourced from internal oscillator and I gate it without a delay:
I get CPLD counter= 17. So based on the internal oscillator frequency and counter value the delay between those two fastDigitalWrites measured is 125.67nSec. The internal CPLD ring osc. frequency has been measured with
and I read 135273234, stable on ~4-5 digits (the ring oscillator is temperature and voltage dependand).
P.
@Graynomad - Xilinx will send you a DVD with the latest development package free of charge, just do register and request it. I got it in a ~week in my post.
You need few GBytes free on your HDD, but frankly, when you understand digital the learning curve is steep as you need just learn few clicks with creating a project, select the device, then draw the schematics (like Eagle, but much simpler), assign the pins (few lines text file), synthetise/compile - one click), and flash (about 3-4 clicks). You need a programmer, I am using an LPT based one - 4diodes, 4resistors and 3V3 voltage reg.. and it works ! :)
graynomad
Quote
I'll do that, thanks.
Quote
It'll take a bit longer to where I live, but no rush.
Quote
Thanks goodness because I can't get to first base with Eagle :)
Quote
Last I looked they had pretty cheap programmers.
I used PLDs in the 80s, I think they've changed a bit since then though.
______
Rob
pito
#4
Aug 27, 2012, 05:57 pm Last Edit: Aug 27, 2012, 06:40 pm by pito Reason: 1
Not much, they have just added a "C"  :)
graynomad
What has changed is the design environment. At home I used small 20-pin chips and the programmer cost $3500. Yikes! I still can't believe I spent that much on a programmer but all dev tools cost a lot then.
At work I used Altera 44-pin PLCC devices, I had to fly down to Sydney for a few days and design the internals on a mainframe CAD system.
Now we get a full dev system for free and run it on our laptops.
It's a brave new world alright.
BTW I used the 20-pin chips in my own dev product I sold, it was an EPROM emulator. Anyone remember EPROMs? Thanks goodness I don't depend on that income any more :)
______
Rob
wwbrown
I ahve kind of curious about CPLDs as they seem like an amazing design space and would like to give them a try the only concern is a compatible programmer.  Could someone point me to programmers for that CPLD that I could use.  It seems like I have collected a few boards and programmers over that never quite mated up with a development environment, now I try to reduce the rate at which components go in the box.
Thanks
wade
pito
hakware
@pito. would you be willing to share the CPLD code? Would save a lot of people the headache of redoing (maybe wrong) the counter.
Thanks!
pito
#9
Oct 07, 2012, 10:53 am Last Edit: Oct 07, 2012, 11:14 am by pito Reason: 1
Enclosed pls find:
schematics file
svf file
xsvf file
ucf file
All under CC BY-SA.. Provided as-is, no warranties of any kind.
Pito.
TonyD
Enclosed pls find:
schematics file
svf file
xsvf file
ucf file
Can you post a pdf of the schematic?
pito
The schematics is the count2.jpg in this thread..
hakware
@Pito, Thanks for sharing your work!
