Topic: Looking for Linear Actuators for small 10W solar panels (Read 5658 times) previous topic - next topic
arjscott
Hi all,
I'm looking for linear actuators, controllable by Arduino with appropriate shield. Can anyone point me to a source?
My project is optimizing the angle of small 10 watt solar panels for maximum efficiency. In other words, I want to track the sun as it moves across the sky daily, with the panels pointing in the optimal direction.
For this, I'm thinking 4 linear actuators at each corner of the panel are the most appropriate.
As a starting point, I'm looking for units that have up to 30cm of extension, with the ability to hold the panel in place in "light to moderate wind".
I would also be grateful if someone would like to translate my layman's explanation into correct technical terms :-)
Thanks in advance.
Andrew.
zoomkat
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
retrolefty
A much more economical solution would be to consider using inexpensive R/C servos. By attaching push rods to extension arms from a rotary servo you can get linear travel. Think how they make a rubber move in a linear manner + and - from a neutral position using a rotary servo in any R/C controlled airplane. You can probably buy 10 or more servos for the price of a single industrial type linear actuator. Servos are available in many sizes to handle just about any torque load, your small panels should not be a problem in that manner.
Lefty
PaulS
Quote
Geez, I always thought airplanes had rudders. Who knew? Sounds like a MUCH more interesting hobby, now.
retrolefty
Quote
LOL, thank you Paul, glad to see your humor coming out sometimes rather then the forehead slaps you give many/most for posting dumb errors or questions. I guess many and most airplanes do use rudders, but then some don't, like the B2 flying wing bomber.
But a servo driven rubber? That kind of smacks of a profitable commercial project idea that could make someone very rich?
Lefty
arjscott
Much appreciated, lefty.
BTW, loving the good natured banter  :)
Thanks guys.
arjscott
Lefty
Gosh. I see what you mean about R/C servos being much more economical!
justone
See what this guy did .
http://www.youtube.com/watch?v=1fUwPSn32T8
trendski
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
arjscott
Hi, have a look at these low cost ones, for schools projects
£5
http://www.mindsetsonline.co.uk/product_info.php?products_id=204
£10
http://www.mindsetsonline.co.uk/product_info.php?products_id=937
Cheers
Thanks! They might be just what I need to get it up and running! I guess it's a ready-made solution somewhat like the suggestions below.
Looks like it will work for me!
keeper63
Why are you wanting to use four linear actuators? Why not two simple and cheap servos with a pan/tilt bracket set (which you can homebrew if you want)?
None of the commercial (ie - large scale) 2-axis solar panel tracker designs use four linear actuators; believe me, they would if it were something that was more efficient for solar.
Also - for most latitudes, 2-axis trackers can be overkill, as the position of the sun doesn't vary enough to change the efficiency of the panel all that much. Instead, you see a single axis being used for the tracker, with the other angle fixed based on the latitude and the average position of the sun in the sky at that latitude over the course of a year...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
arjscott
Yeah. I've realized a 2 axis setup is quite an overkill  :)
I think using a servo for daily sun tracking is enough.
As for the seasonal direction change, I can adjust it manually once every month or two.
