I believe the problem with parallel Leds is that, even if the same part# and from
the same batch, they each have slightly different characteristics [I-vs-V curves]
and one of the Leds will likely hog more of the current and glow more intensely.
That being said, for the case you describe, I should think you'll be ok. One R
shared by all 8 Leds will set the maximum current flow possible, so you cannot
hurt any of the Leds.
Also, when you send pulses down the line, all that'll happen is the intermediary Leds
will pulse on for a short period of time, and you'll probably not even notice it. Even
if you do notice the flicker, all it will do is alert you that something is happening.
Be interesting to experiment with. The flicker-fusion frequency for human
vision is about 30-40 hz, so you'll want the pulses moving a lot faster than that.
