Topic: Still unable to send CC using MIDI Library (Read 11960 times) previous topic - next topic
MikiL
Hello! I'm doing Midi Controller and have tested many different codes to get it work Code in this topi works perfect. But I have trouble to get another potentiometer connected... If I mod the code like this
Code: [Select]
#include <MIDI.h>
// Variables:
int cc_potikka1 = 0;
int AnalogValue_potikka1 = 0; // define variables for the controller data
int lastAnalogValue_potikka1 = 0; // define the "lastValue" variables
int cc_potikka2 = 0;
int AnalogValue_potikka2 = 0; // define variables for the controller data
int lastAnalogValue_potikka2 = 0; // define the "lastValue" variables
  //  launch MIDI
  MIDI.begin(4);
AnalogValue_potikka1 = analogRead(0);
AnalogValue_potikka2 = analogRead(1);
//  convert to a range from 0 to 127:
cc_potikka1 = AnalogValue_potikka1/8;
cc_potikka2 = AnalogValue_potikka2/8;
// check if analog input has changed
if (lastAnalogValue_potikka1 != cc_potikka1)
MIDI.sendControlChange(16,cc_potikka1,1);
// update lastAnalogValue variable
lastAnalogValue_potikka1 = cc_potikka1;
}  //  endif
if (lastAnalogValue_potikka2 != cc_potikka2)
MIDI.sendControlChange(17,cc_potikka2,2);
lastAnalogValue_potikka2 = cc_potikka2;
}  //  endif
and try to mapping that my software (Traktor) and using those as pitchfaders, Traktor move both faders sametime, doesn't matter which fader I touch. Can somebody explain me how this need to change to get it work right?
