Topic: Keenduino board (Arduino clone) (Read 2427 times) previous topic - next topic
cmdrk33n
Hello,
I've designed an Arduino compatible board that can be easily build with throught hole components. It uses an modyfied version of avr-cdc.
- Can run at 5V or 3,3V (selectable with a switch).
- jumper for driving it competely over USB.
- uses avr-cdc for USB to TTL (modified version that gives you autoreset).
- uses an attiny2313 (avr-cdc) and an atmega328p (optiboot).
- runs with 19200 baud.
It is currently work in progress, but i would like to get some constructive feedbacks from you :-)
You can find the current state of the project on my Blog:
http://www.cmdrkeen.net/2012/09/11/building-the-keenduino-ghettoino-rev-2/
I'm happy to see some comments :-)
pico
I like the concept --  very "back to basics" idea, hole through parts and all.
I think you could actually split this into three stages, building it up:
Stage 1: No USB/Attiny, no power regulation. Basically just 328p and crystal. Program via ICSP, or USB->TTY board.
            Bring your own regulated power supply at 3.3 or 5.0V.
Stage 2: Add power regulation, but still have to program by ICSP or USB->TTY board.
Stage 3: Add USB/Attiny, can now program by ICSP, USN->TTY board, or USB.
Good work! 3.3V is a nice option.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
cmdrk33n
Hello pico, thank you for your feedback :-)
yep, it's a very good idea to offer also a basic design, it would give newcommers a better understanding of what is essential for an arduino board.
There are plans for an ICSP port (because it is simply a must have). but sadly i didn't had the time to add it, but it is planned for the first update.
my plan is to make a pinout for the attiny2313 too and connect both to the ICSP port, so you have the abillity to reprogram both MCU's.
pico
The other thing that would complement your design nicely is a small pcb layout, perhaps one that could be made to fit the size limits of the inexpensive "10 boards for $10" pcb board makers (itead/seeed etc.) Just a thought, if things could be made to fit. That would be a pretty slick "DIY Arduino" project, then, I think.
