Topic: Accurate resistence measurement without reference resistor? (Read 10136 times) previous topic - next topic
MrGarak
Is it possible to get an accurate (say 0.05%) measurement of a resistor using the arduino, but without having to rely on a reference resistor? The best I have to work with right now is a 10k 1% resistor. I'm trying to use a 10k thermistor and would like to get an exact value for the 10k reference resistor. Unfortunately, I don't have a multimeter and I think that only something like a fluke 87 could give me an accurate reading anyway (from what I've heard the cheaper ones don't have as accurate an ohmmeter). I'd like to get an 87 but that's currently not in my budget at the moment.
I suspect this isn't possible, but figured I'd ask anyway.
DVDdoug
Quote
No...  I'm not sure about accuracy of the ADC... can check ATmega specs for that.   But at 10-bits, the BEST resolution you can get at full-scale is 1/1023, which is 0.10%.   At lower ADC readings the percentage resolution of one bit is of course, worse.   As a measurement "instrument", I would not expect the Arduino ADC to be anywhere close to a real multimeter...
dc42
I think you will find that the tolerance of your 10K thermistor is 1% or worse, so having a precision reference resistor doesn't help. If you want accurate results, you should calibrate the combination of thermistor and reference resistor against an accurate thermometer.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
MrGarak
Yea, I assume it's 1%. I just wanted an accurate reference value. I figured this wasn't possible due to the errors of the components involved (ADC, resistors, cheap multimeter). I do have another thermometer to test against but not sure it does much good if I can't get an accurate reading for the 10k 1% reference resistor.
dc42
MarkT
If you have one or more 0.1% reference capacitor(s), you might be able to measure resistance by measuring RC time constant....  You charge and discharge the capacitor via one digital output through the unknown resistor.  The voltage at the R-C connection is measured with an analog pin and the output inverted when the cap has charged or discharged a given amount (relaxation oscillator).
So long as the time constant is fairly long you can get good accuracy (you only sample the voltage every 0.1ms or so with the ADC, so a time constant of 0.1s or more is needed).  Take 1/4 and 3/4 of the supply as endpoints, thats analog values 256 and 768, and you'll be switching outputs every 1.0986 x R x C seconds.  ln (3) = 1.0986
You'll have to allow for the output resistance of an output pin though.  And the fact that capacitors aren't as ideal as you might hope.
retrolefty
Best to keep the complete A/D accuracy thing in proper perspective before you take too much effort and time looking for perfect components.
The Atmel A/D accuracy specification from the datasheet is:
Quote
• ± 2 LSB Absolute Accuracy
That's a pretty loose spec.
Your default reference voltage used in the A/D conversion is either the USB +5vdc or the on-board +5vdc regulator if using external power connector, neither which will be exactly +5.000000 and neither will they be the same.
The Arduino analog input pins are very useful for lots of things, but making high precision measurements is not one of them. External A/D chips with better resolution, internal voltage reference, switchable gain values all lend themselves to much better measurements if your application requires it.
Lefty
MarkT
And I've just realised with my RC idea that it relies on the board having a quartz crystal, not a ceramic resonator, as its system clock.
Yet another reason to grizzle about the Uno's cheapskate clock source compared to earlier Arduinos.
MrGarak
I think the capacitor current idea would probably only shift the problem to "how accurate are the reference capacitor values" instead of how accurate is the reference resistance value. I have suspected the arduino's ADC wouldn't be up to the task of taking full advantage of a 0.1c accurate or better thermistor anyway. For whatever it's worth I was using the 3.3v and analog reference vs the 5V. Seems the only real solution is a fluke 87 or better to pin down the reference resistance value, and then a quality 12 or 16bit ADC to poll the thermistor. A third option, of course, is an integrated chip thermometer solution, I've had my eye on the SHT75 for that reason. No need to worry about calibrating those either since they're supposedly already calibrated. It just would have been nice to have some accurate thermistors employed in addition to that to get a more accurate average temperature reading.
Docedison
A Calibrated Thermometer isn't nearly as expensive as a Fluke 87 and for that matter neither is a Fluke 87 that accurate:
Resistance
Maximum Resistance:    50 M?
Accuracy:    Fluke 83 V: ±(0.4%+1)
Fluke 87 V: ±(0.2%+1)
Maximum Resolution:    0.1?
From the data sheet at this URL:  <<http://www.fluke.com/Fluke/usen/Digital-Multimeters/Fluke-80-Series-V-87V-83V-87V-E2-Kit.htm?PID=56135
And at $399.00 Much too Much overkill for an Arduino for it's other features and resources. Great accuracy requires many different things and the resistance measurement is just one.
An Arduino is capable of just that degree of accuracy however it requires some thinking first.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
jackrae
Out of idle interest, why would you want your thermistor temperature reading to be accurate to better than 1%.   There is much confusion about the measurement term "accuracy".
Accuracy relates to comparison against a national standard, which from the layman's point of view, is generally irrelevant.
What is generally required is "repeatability" not "accuracy".   A repeatable device means that several readings taken at different times of 'exactly' the same value will give repeatable results.   These measurements may not be 'accurate' but they are consistent.
MrGarak
Doc, retro, and others, thanks for the helpful information. The 87 I was planning on simply getting a used one on ebay when the time was right. You can usually get them for quite a discount and there are always ones up for auction. As for the reason, I'd ideally like my temperature sensor to be accurate to the tenth of a degree Fahrenheit. This is for a weather station project. From all my research on the matter, it seems the best I'll be able to do is ~0.2C (0.36F) accuracy , and that's with an integrated sensor package such as the SHT75. I did want to add a couple thermistors to complement the 75 (for backup and accuracy reasons), but it appears in order for that approach to be feasible I'd have to purchase a .05% tolerance 10k resistor for the reference, and either use a 12-16bit ADC alongside a 0.1% thermistor, or else use some type of multisampling solution to improve the arduino's native ADC resolution. Not sure if it's worth all that hassle, especially since they'd also each have to be calibrated too, and I'd have to use ones with known steinhart-hart coefficents or else an extensive thermistor table. The one I am testing with right now has no part number or anything so it's truly a mystery.
JoeN
You can get 0.1% tolerance resistors quite easily and cheaply, especially if you are prepared to use SMD components.
I see Digikey has quite a good selection of through-hole ±0.1% resistors for 55 cents each / 42 cents each at 10 / 6 cents each for 5000.  Prices come down quite a bit if you need a a pile.   Just search 'Resistors' and modify the search criteria ("parametric search") for ±0.1% tolerance
I will never ask you to do anything that I wouldn't do myself.
dc42
If you want high accuracy and resolution, I think you had best use a sensor module, such as the SHT75 you refer to. If 0.5C accuracy and resolution is sufficient, then the Dallas DS18B20 is an inexpensive choice.
Another possibility is the LM34, which if used with the Arduino's 10-bit ADC with Aref connected to a precision 2.5V bandgap reference (LT1019) will give you 0.24 degF resolution and uncalibrated accuracy of about 1degF or better.
Docedison
IF you need repeatable accuracy of .1d deg F you will need to use a Platinum RTD sensor, .3 Deg can be done with a thermistor or much better an Analog Device AD592... 1 degree is easily done with an LM34/6 and 2deg is easily done with a TMP36. There are resources in the Playground referring to calibrating or 'normalizing' a thermistor's output and there is a man named Anderson, P. H. Anderson who has a website and there you will find tables of data for normalizing thermistors as well as the calculations to do so. The AD592 is probably the best device overall for accurate repeatable and reasonably priced temperature measurements. I've attached data sheets for all three.
Doc
--> WA7EMS <--
