Topic: STRING To HEX Converter (Read 30538 times) previous topic - next topic
Shruty19
Also is there any way to left zero pad in string?
PaulS
Code: [Select]
       ret = strtoul(nes, &ptr, 16);
The strtoul() function does not take a String.
Quote
Yes.
You post code that won't compile. You don't show what is in the String instances. You don't show the output. ALL you do is whine "it doesn't work".
I'm convinced that you don't want help.
TolpuddleSartre
nes is a String, but strtoul expects a char array.
That's why you get an eror.
The String class has a method to turn Strings into strings.
Or, you could cut out the middleman, and not bother using Strings in the first place.
