Topic: [UPDATED] motion detector that works behind clear glass window? (Read 29684 times) previous topic - next topic
BlueJakester
Sep 21, 2012, 12:03 am Last Edit: Sep 27, 2012, 05:44 pm by BlueJakester Reason: 1
I did some searching but found only posts in the old read-only forum. I thought there may be more current information and/or products, so posting the question here.
I'd like to connect a motion detector to an Arduino and have it point at my porch from behind a clear glass window. Someone approaches my door and the Arduino is triggered.
Can someone recommend a motion detector that works from behind glass, or recommend what I should be searching for?
Thanks,
Jake
Far-seeker
One thing to keep in mind is that common forms of glass aren't as transparent to infrared light as they are to visible light.  Therefore IR based motion detectors, like PIR, might not be the best for this application.  Other than that I don't have any specific advice.
oric_dan
Ultrasonic and PIR motion sensors will likely not work in your case, so
you'll probably have to go to some kind of computer vision scheme.
And probably will not be super easy to do.
I have read about people using simple CdS cells to detect motion [place
in a tube for directionality, and program A/D converter to sense "rapid"
changes], but these things are sensitive to all sorts of light-intensity
changes, ie "false positives". Welcome to the world of signal detection.
johnwasser
If you have a location on the other side of the porch where you can put a reflector you could use a "laser tripwire" to detect objects crossing the laser's path.  The laser and light detector would be inside the window.  A small mirror would reflect the laser light back to the light detector.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
radman
I agree with the comment about IR. I tried taking pictures using an infrared camera looking out through a window. What it picked up were reflections of heat sources inside the room on the glass but not what was outside.
Maybe this is a doge but if you can put small mirrors outside then you could reflect a light off them and detect the reflection. If the 'beam' was cut you could alarm.
oric_dan
Oops, I missed the point about the porch.You probably wouldn't need
something as complex as a laser, but just a blinking "infrared" led, a
mirror, and a pickup. The blinking would be used as a synchronous
signal, and that would effectively eliminate stray background pickup.
Basically, 40-khz stimulation and TV IR-remote detector, although those
are probably much more sensitive than you would need.
IR Led will help eliminate regular light problems. Note - normal IR Leds
and sensors operate in near-IR range, about 880-940 nm, while PIR operates
in far-IR range, about 10000 nm [IIRC], so you'd actually be dealing with
light and not heat.
radman
johnwasser: We seem to have come up with the same idea, I did not see your post before sending mine.
BlueJakester: If you are going to use an IR LED check if you really can detect it though the glass. If you can then blinking sounds like a good idea, but make sure it is fast enough that a leg swinging through the beam will be detected.
BlueJakester
Thanks everyone for the excellent suggestions. I like the laser - mirror - photocell idea. Sparkfun has some lasers like this one and I could reflect the beam into photocell attached to an Arduino.
That would be a fun project to put together and learn from. If I do it I'll let you know how it goes.
spcomputing
Oh, this could cause some excitement:
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/ProductID/606/List/0/Default.aspx?SortField=ProductName,ProductName
Haven't tried it myself, but looks interesting.
Lavan
I used a PIR sensor module for the motion detection for a security light and fixed everything in a small transparent plastic box (PIR sensor module also inside the box).  It is working fine without any issues.  Whenever there is a motion it switches on the light.  So I believe it works for your case as well with out any issues from behind the clear glass. Just give a try!!
teckel
Now that DOES seem interesting!  Motion detection through walls!  Love it, want!
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
Far-seeker
Plastic an glass are very different categories of materials, and even different types within those categories can have very different optical or other physical properties.  Furthermore, just because something is transparent to one set of electro-magnetic (EM) wavelengths doesn't mean it will be for another, even if the two sets are close to each other on the EM spectrum.  Based on my own experience with IR sensors, in the mid-to-long infrared wavelengths (which is what PIR uses) window glass doesn't act like much of a window.  There are of course types of glass that would be transparent to these wavelengths, but most aren't the type you'd get at your local hardware, art supply, or hobby store.  Instead, you'd have to start with organizations that sell laboratory grade glassware and/or specialty optics.
BlueJakester
#12
Sep 27, 2012, 05:43 pm Last Edit: Sep 27, 2012, 06:05 pm by BlueJakester Reason: 1
UPDATE: I received the parts I needed and finally had the time to setup and test in my shop.
I'm directing this laser beam across the room into a mirror where it reflects back into this photocell. I placed a large diameter piece of heat shrink, about 1" long, around the photocell like a sleeve to cut down ambient light. At this time there is no glass window between the beam and mirror. When the beam is interrupted an LED illuminates.
The reaction time of the photocell is plenty fast enough. The main loop() in my code is running without any delay. I can swing my hand through the beam in a karate chop motion and reaction is fast enough to trip and light the LED. I can flick my finger (like you were flicking a piece of sand off a  table) through the beam and it triggers the event.
I do have one concern so far though. Trying to line up that dot of laser beam in the mirror and direct it back to the photocell is tedious. The slightest touch or bump of either mirror or Arduino and the beam is no longer hitting the photocell.  Any ideas on how to make that part easier?
I also am going to need some sort of a small mirror on a swivel joint. The mirror I have now is about 2"x3" and no swivel. Something like a motorcycle rear-view mirror would work, but that would be way too big and noticeable  on my porch. Any ideas?
Thanks,
Jake
johnwasser
If you get an analog input from the photocell you can use that to generate a tone which will give you audio feedback for the aiming of the mirror.
BlueJakester
#14
Sep 27, 2012, 06:15 pm Last Edit: Sep 27, 2012, 08:19 pm by BlueJakester Reason: 1
Thanks John. I reversed the event ... when the beam of light hits the photocell the LED lights. Now I can determine from across the room when the beam is lined up. Break the beam, LED goes off. If I put this project into actual use, I will put a timer on the LED to go out after a few minutes of making alignment.
It's still difficult and tedious to make that alignment. I suppose that's just the way it is going to be.
