I'm having trouble getting data onto an SD card.
The object is to
read two DS18B20 thermometers.
display the information, including the difference derived from these readings, every second on mnonitor and LCD. This works fine.
create a file named by the date on startup, and a new one every 24 hours at midnight. This works fine, I think. Included as part of this is a line of fixed text, just a heading. This is duly written, showing there is nothing wrong with the card or the write process.
write the data to the SD, but only every ten seconds and only at certain times of the day. This does not work, I just get the heading.
The sketch compiles OK. There are only two open/close commands. The first is in setup to name and check the card. The second is near the top and at the bottom of the main loop. The procedure in each is the same but I think it only works in the setup. The sketch does go through the write subroutine OK. I have put in a serial.print at the bottom to check this.
The code is pretty long, so I have stripped out the extraneous stuff. I imagine this is something silly and obvious, and hopefully clear in the section below.
Thank you.
#include <LiquidCrystal.h>
#include <SD.h>
#include <string.h>
#include "RTClib.h"
#include "Wire.h"
#define DS1307_ADDRESS 0x68
#define tture1 14//no ; here
#define tture2 15//no ; here
RTC_DS1307 RTC;
File myFile;
char filename[] = "00000000.CSV";
LiquidCrystal lcd(8,9,16,5,6,7);
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
int TDiff, Tc_99, DiffWhole, Diffrac, hour, minute, second, Whole1, Fract1, flag;
//For each tture sensor: Do a pinMode and a digitalWrite
pinMode(tture1, INPUT);
pinMode(tture2, INPUT);
digitalWrite(tture1, LOW);//Disable internal pull-up.
digitalWrite(tture2, LOW);
flag == 0;
lcd.begin(16, 2);
Wire.begin();
delay(300);//Wait for newly restarted system to stabilize
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
if (!SD.begin(4))
Serial.println("initialization failed!");
return;
Serial.println("initialization OK.");
FileName();
myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN
// if the file opened okay, write to it: This is an IF-THEN-ELSE on validity of myFile
if (myFile)
Serial.print("Writing to file...");
myFile.println(" date, time, temp., IN, OUT, Diff");
myFile.close();//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CLOSE
Serial.println("done.");
Serial.println(" date time temp. IN OUT DIFF");
Serial.println("error opening file");
printDate();
if (hour == 0 && minute == 0 && second == 0)
FileName();
myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN this happens every time round the loop!
Serial.print("\t");
lcd.setCursor(2,0); //first temp read print to LCD
readTture(tture1);//N.B.: Values passed back in globals
Tc_99 = Tc_100; //keep the first reading
printTture();//N.B.: Takes values from globals. Also... //print Temp1
//no newline part of pritTture;
Serial.print(" ");
Whole1 = Whole; // for FIRST Temp to SD
Fract1 = Fract; // for FIRST Temp to SD
delay(200);// Delay... must not be too short.
readTture(tture2);//Now read and report 2nd tture.
lcd.setCursor(10,0); //setup for second temp read print to LCD
printTture(); //print Temp2
TDiff = Tc_100 - Tc_99; //diff
Serial.print(" ");
lcd.setCursor(2,1); //setup for third temp diff to LCD
if (TDiff<0) // If it's negative (Must do this here. T1 T2 done in read srtn)
Serial.print("-");
lcd.print("-"); // here now but rest a lot later!
TDiff = TDiff * (-1);
flag == 1;
Whole = TDiff/ 100; // separate off the whole and fractional portions
Fract = TDiff % 100;
delay(200);
printTture(); //print Temp3
Serial.print("\n");//Start new line
flag == 0;
delay(600);
// end of main loop >>>>>>>>>><<<<<<<<<<<<<<<
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse
}//end OneWireOutByte
byte OneWireInByte(int Pin) // read byte, least sig byte first
}//end OneWireInByte
};//end readTture
void printTture(){//Uses values from global variables.
//See global declarations.
//N.B.: No new line inside printTture
Serial.print(Whole);
Serial.print(".");
lcd.print(Whole);
lcd.print(".");
if (Fract < 10)
Serial.print("0");
lcd.print("0");
Serial.print(Fract);
lcd.print(Fract);
lcd.print(" "); // just to get rid of strays due to shifting for - sign
};//end printTture
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
void printDate(){
// Reset the register pointer
Wire.beginTransmission(DS1307_ADDRESS);
byte zero = 0x00;
Wire.write(zero);
Wire.endTransmission();
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
Serial.print(monthDay);
Serial.print(second);
Serial.print(" "); // followed by all three temps to SD card!
// after the
// NO ACTION IF THENs
//if (hour < 5) // No action midnight to 5am
// {return; }
if (hour == 23) // No action 11pm to Midnight
{return; }
//if (hour > 8 && hour < 17) // No action 9am to 5pm
// {return; }
// ACTION!! but only every ten seconds
if (second == 0 || second == 10 || second == 20 || second == 30 || second == 40 || second == 50)
myFile.print(monthDay); //date start
myFile.print("/");
myFile.print(month);
myFile.print("/");
myFile.print(year);
myFile.print(", ");
myFile.print(hour);
myFile.print(":");
myFile.print(minute);
myFile.print(":");
if (second < 10)
myFile.print("0");
myFile.print(second); // date end
myFile.print(", ");
// Temps not done by printTture, so done here
myFile.print(Whole1); // Temp 1
myFile.print(".");
if (Fract < 10)
myFile.print("0");
myFile.print(Fract1); // Temp 1 ends
myFile.print(", ");
myFile.print(Whole); // Temp 2
myFile.print(".");
if (Fract < 10)
myFile.print("0");
myFile.print(Fract); // Temp 2 ends
myFile.print(", ");
// Temp 3
if (flag == 1)
myFile.print("-");
myFile.print(DiffWhole);
myFile.print(".");
if (Diffrac < 10)
myFile.print("0");
myFile.println(Diffrac);
Serial.println(" write to SD card");
// IF THEN ends
void FileName(){
DateTime now = RTC.now();
filename[0] = (now.year()/1000)%10 + '0'; //To get 1st digit from year()
filename[1] = (now.year()/100)%10 + '0'; //To get 2nd digit from year()
filename[2] = (now.year()/10)%10 + '0'; //To get 3rd digit from year()
filename[3] = now.year()%10 + '0'; //To get 4th digit from year()
filename[4] = now.month()/10 + '0'; //To get 1st digit from month()
filename[5] = now.month()%10 + '0'; //To get 2nd digit from month()
filename[6] = now.day()/10 + '0'; //To get 1st digit from day()
filename[7] = now.day()%10 + '0'; //To get 2nd digit from day()
