Topic: My mosfet is heating, can't understand why (Read 11760 times) previous topic - next topic
MarkT
Quote from:  link=topic=124963.msg940899#msg940899 date=1349098312
MOSFETS only get hot when they're not completely switched on. When they're completely on or off their resistance is so low/high that the power dissipated by the MOSFET is negligible.
WHAT?
When a MOSFET is completely on its resistance will be <= Rds(on) [max]. (Provided Vds << Vth).  Its power dissipation is I-squared-R which can be _extremely_ large.  It all depends on the values of I and R.  30A and 0.01ohm gives 9W, 10A and 0.2ohm gives 50W, 4A and 0.006 ohm gives 96mW.   96mW needs no heatsink, 9W needs a big heatsink, 50W requires large heatsink and/or water- or forced-air-cooling.
You have to _calculate_ the on-state dissipation.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
fungus
WHAT?
Ok, maybe I shouldn't have said "only". OTOH 30A is a monstrous current.
Advanced Arduino
dhenry
Quote
For <$20, you get a ESC, built around a MEGA8, that switches that much current, FAST too.
MarkT
All the time people get MOSFET overheating issues here because they don't know things like :
1)  power = I-squared-R(on)   is the way to choose a MOSFET.
2)  Vthr is not Vgs(on)
3)  > 0.3W necessitates a heatsink
4)  > 5W needs quite a large heatsink or a fan
5)  An IRF520 is totally obsolete
6)  The max current rating is irrelevant unless you are using a water-cooled heatsink!
Its very common to see people believe a 10A MOSFET will take 5A continuous without any thermal issues(!)
dhenry
Quote
Absolutely correct.
Those current ratings are pulsed, and with the case temperature (typically) at 25c.
Effectively, you need absolutely perfect case-to-ambient heat transfer for that rating to be relevant.
retrolefty
I would add:
7) Gate drive current can be significant in high power (high gate capacitance) mosfets switching at high speed and often a purpose designed high current gate driver chip is called for.
8 ) Higher switching frequencies increases device dissapation as more transitions accure per unit of time and becomes a significant contributer to device losses.
