Dear Forum,
I need to control a device with a 0-1V input that supplies at least 200 mA of current (500 mA max). I have limited electronics knowledge and have scoured the net to find a simple solution but as far as I can see, most voltage regulators tend not to work at this low voltage range.
Can any one help with a circuit?
I would like to do this using the same voltage source that supplies the arduino so I am looking to use a single rail, low voltage power supply.
I know how to convert PWM to analogue out and how to use an OP amp to buffer the output but this is not sufficient current for my needs. I need to know how to wire up a suitable voltage regulator circuit to supply enough current.
If it is easier, I could live with a system that just switches on 1V rather than modulating between 0 and 1 but would prefer the modulation if it is reasonably straight forward.
Thanks,
Nick
