Topic: >> Resolved << : MEGA with cardinfo.h and "LC studio" SD card reader dont work (Read 39877 times) previous topic - next topic
LibertyCareche
#15
Oct 10, 2012, 07:10 am Last Edit: Oct 10, 2012, 07:15 am by LibertyCareche Reason: 1
Yes, your right... I passed my time to work on electronics and not translation... it becomes like that... sorry !?
It would be more positive for you to write this ... in French... no ?
There are people who collect posts by this way,... there is others who work... it's the life.
But... thx
NSEVILLIAN
I had the same problem with the MEGA and I was able to change the pins within the code and it worked properly. thank you for the help.
below is the code I used and I modified it/made notes for some more people can understand.
  SD card test - It checks to see if the wiring is correct, card is inserted and compatible ( Used: LC STUDIO SD CARD READER )
 This example shows how use the utility libraries on which the'
 SD library is based in order to get info about your SD card.
 Very useful for testing a card when you're not sure whether its working or not.
 The circuit:
  * SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
       Pin 4 used here for consistency with other Arduino examples
 created  28 Mar 2011
 by Limor Fried
 modified 9 Apr 2012
 by Tom Igoe
 modified 17 July 2015
 by Nandi Sevillian
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
/*FOR MEGA PLACE THESE PINS FOR THIS TO WORK
 * NOTE THAT I DONT HAVE A SHIELD just the LC STUDIO SD CARD READER AND ARDUINO MEGA
 * MEGA pin 50 -> miso (Master in) Card Reader "LC studio"
 * MEGA pin 51 -> mosi (Master Out)
 * MEGA pin 52 -> sck (Serial Clock)
 * MEGA pin 53 -> CS (Chip Select)
 * I have a SanDisk 8GB SDHC Card inserted inside and it works properly.
const int chipSelect = 53;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
      break;
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
      break;
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
      break;
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  Serial.println();
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
when the Serial monitor is open then this is my print statement
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 3644850176
Volume size (Kbytes): 3559424
Volume size (Mbytes): 3476
