Topic: Components designated "SK"? (Read 10911 times) previous topic - next topic
Zapro
shock sensor
www1.futureelectronics.com/doc/MURATA/PKGS-00LD-R.pdf
And you found it necessary to revive this old thread to post the same link as I posted Feb, 9?
// Per.
krupski
#16
May 29, 2017, 09:12 am Last Edit: May 29, 2017, 09:14 am by krupski
Piezoelectric shock-sensor. Moves the heads to a safe place on the platters, and probably sets a bit in the chipset that tells the manufacturer that you invalidated your warranty.
http://www1.futureelectronics.com/doc/MURATA/PKGS-00LD-R.pdf
// Per.
Sorry this reply took so long but your info was posted 3 years after I initially asked, so I had long since given up on the question and never saw your post until now.
Anyway, I'm 100% sure you nailed it. The parts are designated "SKn" which makes sense... SK=shock. And, one of the links you posted mentioned that the hard drives which use these usually mount 3 of them at 45 degree angles to each other (again makes sense to determine which direction a shock came from)... and indeed the PC board photo I posted is from a hard drive and they are at 45 degrees to each other.
So, besser spät als nie, Ja?... thank you for the reply and the info... and a Karma++ for you too.
Thanks again!
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
