Topic: Components designated "SK"? (Read 10941 times) previous topic - next topic
krupski
Hi all,
Can anyone tell me what an "SK" component is?
On a hard drive controller board, there are several of these things.. "SK1", "SK2", etc...
They are SMT devices about 5mm long by 3mm wide by 2mm tall. They look like they are made of maybe quartz (translucent clear/white look) and there are three layers of the "quartz" stacked on top of each other and in parallel. They have two terminals (one on each end).
Anyone know what these things are? I Googled (or tried to) and didn't come up with anything meaningful.
Thanks!
-- Roger
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
Tom Carpenter
~Tom~
krupski
MarkT
Intriguing - could be a socket (you'd need to the other side of the board).
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
Docedison
Judging from the image and the image of the other footprint it looks like some kind of resonator... 2 different case styles/purposes But still from that white SK2 part and there are at least 2 caps visibly connected so my thought about a resonator. It's not a diode or spark gap which might have similar designators (Surge arresters of both gaseous or semiconductor types 'might be marked that way). I've serviced a lot of test equipment and seen things similar but not identical to those parts/footprints.
Bob
--> WA7EMS <--
AWOL
The metal pattern does look fuse-like.
The presence of power supply sockets or high power devices like power transistors nearby might clinch it.
JoeN
Could you post a picture?
Sure!
My web blocker blocks this.  I wonder why...  gunsnet.net   Hmmm...
I will never ask you to do anything that I wouldn't do myself.
Docedison
The single thing that stood out to me was the size of the traces... Protective devices usually have shorter and Much wider traces, those appear to be 8 to 10 mil traces or inductors in series with the protection. I really don't know what the parts actually are I just tried to figure out "IF" those were protection devices than it would be a mistake to use small "wires" (PCB Traces) to provide the interconnection. These are part of "Basic" design rules for PCB layout and my reasoning in "reverse" engineering the subject.
Bob
--> WA7EMS <--
krupski
Could you tell me which web blocker you are using?
JoeN
It's a corporate blocker - WatchGuard.  It blocks it due to "weapons" which I guess is proscribed here at the copper mine.  It blocks adult stuff and "hate" and other categories deemed to be detrimental to productivity, including eBay (but not Amazon).  Sometimes it makes really stupid mistakes.  It has a Las Vegas newspaper blocked due to "adult" - maybe there is a section on there on topless shows or something.
kleon
Sorry for delay  :D
Anyway that component is a vibration sensor. The IC uses it to compensate any kind of shock or vibration.
Paul__B
It's a corporate blocker - ... Sometimes it makes really stupid mistakes.
Oh, only "sometimes" eh?
This is the crucial danger when some loony politician (or pit thereof) determines to "filter" the Internet.
Oh wait - the UK!
Zapro
Piezoelectric shock-sensor. Moves the heads to a safe place on the platters, and probably sets a bit in the chipset that tells the manufacturer that you invalidated your warranty.
http://www1.futureelectronics.com/doc/MURATA/PKGS-00LD-R.pdf
// Per.
shahroozmufi
shock sensor
