Topic: 2010 vs 2009 (Read 1 time) previous topic - next topic
Nachtwind
I just came back from a workshop and have seen that there seems to be a new set of arduinos available.. yet i wonder - what is the big difference. Is it "just" the new USBSerial chip? If so, what would be the big advantage above the 2009?
I read that the UNO will now be the reference hardware - will that somehow make the 2009 obsolete or incompatible with upcoming builds?
Sorry for those stupid, and most surely already answered questions, but i havent found any topic covering those things so far..
keeper63
Quote
Basically - that, and the new name. From what I understand, it still uses the 328, along with a more streamlined bootloader (optiboot?) - I am not sure if this particular bootloader is smaller (the smallest you can have is 512 bytes), to allow for slightly larger programs to be loaded, or if it has just been optimized for faster upload speeds - or both...
As far as the new USB interface is concerned, you'll only likely see a "compatibility" issue if, for instance, someone changes or builds a project to change the firmware on the ATTiny (?) being used for the USB interface in such a way for the project, so as to change it to identify differently, or act in some other strange manner for the project so that a standard Arduino with an FTDI chip won't work.
I think though, that for regular usage (other than, again, faster upload speeds and possible bootloader sizes), the difference will be negligible.
Quote
Other than what I noted above, I doubt it. Think also of the large "installed base" of 2009 Ardunios - it is huge (for our market, of course); even if there were such an issue to arise, which I doubt, you would see attempts at "backporting". Likely one of the first things you'll see done, which might just be a "simple" re-burn - is putting the optiboot loader onto the 2009 Arduino (ie, the 328). You might also see interest in further "hacking" of the FTDI.
I honestly don't think there will be any "abandonment" going on (heck, they kept the same form-factor when they could've fixed the weird pin spacing - which, IMHO, they should have done - this was the one chance for a clean break, and for whatever reason, it was ignored). Also, note that the software still supports the really old-school DB9 serial ATMega8 Arduinos - which haven't been made in how long now?
If you have the money, I would take the time to look out for Arduino Duemilanove deals, as vendors move to bring the UNO into their lineup. I wouldn't worry about your current set of Arduinos being made obsolete or anything. This change is mostly about making the Arduino even more open (via the new USB chip - which we can now re-program - there's already a tutorial out on changing it!), and updating the "brand" so that it is easier for non-Italians to converse about the Arduino (Uno vs. Duemilanove).
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Nachtwind
Thanks for the clarification... about the bootloader.. are there any experiences (yet?) about putting them on 2009er? Maybe on the Mega?
wortelsoft
The optiboot thread is here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1271415071/all
He optiboot is smaller and faster in uploading. There is a new version of it in the 0021 version because of a bug with some PWM outputs.
westfw
Quote
There is a new version of [optiboot] in the 0021 version
Actually, the problem was fixed by changing the Arduino core.  This way, you don't have to change the bootloader in all those pre-programmed Uno chips...
