Topic: Programming an ATtiny85 with Arduino Code and Arduino Uno as Programmer (Read 12163 times) previous topic - next topic
marian42
I downloaded this from your thread.
It worked with my single attiny (the core from MIT media lab worked with this one as well) but not with my onboard attiny.
Only the power led of the programmer lights up.
This is the error:
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done.  Thank you.
Coding Badly
Did you try the ArduinoISP sketch from the link I posted?
funkyguy4000
I tried that one codingBadly,
I keep on getting an error invalid conversion from 'const char*' to 'uint8_t'
Accelerate to 88 miles per hour.
Coding Badly
Binary sketch size: 5,176 bytes (of a 32,256 byte maximum)
Compiles for me using Arduino 1.0.1 on Windows with Arduino Uno as the selected board.
marian42
Im sorry I didnt find the attachment in the first place.
I tried the ArduinoISP sketch from the attachment.
However, I got the same results.
The two ArduinoISP sketches are identical, exept in line 126 heartbeat(); is commented off.
Riva
I watched the board being programmed with the ATtiny soldered on it so Im quite sure its possible. It has eight holes for programming.
What device was being used to program the ATtiny? Maybe someone with greater knowledge of Atmel chips can say if you can still program these chips using ArduinoISP if the reset disable and/or the SPI program fuse is set, or do you have to use high voltage programming?
marian42
I assembled the board on an exhibition myself and it was programmed by a self-made piece of hardware that was connected to a laptop.
I asked whether it is possible to program it my self with an arduino and I was told to use the tutorial from MIT Media Lab.
Tom Carpenter
if the reset pin is disabled and/or spi programming is disabled then you have to either use a hv programmer to program, or a hv programmer to set the fuse byte to enable both the reset pin and spi programming bits and then you can use isp to program again.
~Tom~
marian42
Im not sure about the reset pin but they told me that it is possible to lock ATtinies and that this one is not locked.
fungus
You need HVP if the reset pin has been configured as an I/O pin.
Advanced Arduino
fungus
You can "lock" it against SPI programming is by configuring the reset pin as a general I/O pin. I don't think there's any way to lock them against special programmers (HVP).
Advanced Arduino
Tom Carpenter
There is something else you can do if you want an extra IO pin, but still want to be able to program without a HVP, and that is to use a bootloader - the one I made for tiny85s and 84s is designed to allow serial programming (software uart) without the need for a reset pin.
~Tom~
Coding Badly
If you want me to continue helping, post the verbose output.
Coding Badly
marian42
Verbose output varies randomly between the one posted in #17 and this:
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATtiny85
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avrdude: Send: P [50]   [20]
avrdude: Recv:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
I do not see any connection at the reset pin but I can barely see any connections at all because the PCB is covered with some kind of black ink so the wires are only slightly lower than the rest.
