Topic: Rfid Door Lock (Read 15336 times) previous topic - next topic
Bobbyfox2
Q1... What is the voltage and current is your door strike
Q2... I am having trouble seeing where the prototyping board connects to the id-12 could you please help me out
Q3... I am also having trouble seeing how the buzzer connects up could you please help me
Q4... Could you please tell me if the transistor that i have will work. Here is the link: http://www.jaycar.com.au/productView.asp?ID=ZT2468
Q5... Is that a diode just behind where the door lock connectors are if so could you please tell me what diode i need
Q6... Could you please tell me what resistor or resistors i need could you please tell me
Q7... Could you also please tell me where everything goes on the prototyping board if you could do that it would be very much appreciated
Q8... could you also please tell me what D8, D7, etc.  mean
Bobbyfox2
GaryP
My door lock uses 24V.
Thanks for asking.
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
nickgammon
I think this question was addressed at me, based on various personal message I have got recently. :)
In particular with reference to this project:
http://www.gammon.com.au/forum/?id=11283
12V. Not sure of the current. Still, it's the current of your strike that is important, right? A few hundred milliamps from memory.
As shown above.
As shown in the circuit.
That should be OK.
As on the circuit. I used a 1N5822 (Diode Schottky 40V 3A) to protect the circuit from the coil.
Are you having trouble reading the circuit?
Wherever you want to put it, it isn't critical.
They refer to the digital pins on the Arduino.
nickgammon
would this transistor be better
LINK:  http://www.jaycar.com.au/productView.asp?ID=XC4244
Looks about the same. Looks like it has the pull-down resistor already installed.
Bobbyfox2
Bobbyfox2
What does the triangle facing down on the buzzer mean (schematic)
GrooveFlotilla
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
Grumpy_Mike
It is ground, all those points are connected together.
Bobbyfox2
How do you connect to ground
GrooveFlotilla
Use a big copper spike.
Are you being serious?
Bobbyfox2
how do i ground to the board
AWOL
Ground, zero volts, earth.
GaryP
Are you sure you want to do this?
Cheers,
Kari
Grumpy_Mike
Ground is one of the terminals on the arduino bord. It is marked GND.
All points with that triangle must have a connection to that point.
So join all the triangles together and then connect that to the GND pin.
