Topic: Arduino synthesiser with leds (Read 4894 times) previous topic - next topic
alepom
Oct 23, 2012, 03:07 pm Last Edit: Oct 26, 2012, 08:27 pm by alepom Reason: 1
I would like to build this famous project:
http://code.google.com/p/tinkerit/wiki/Auduino
, but adding the LEDs to obtain this result:
http://www.youtube.com/watch?v=UJqY6U8fSmY
Is there anyone who can help me for the changes?
I tried to look for the project, but I have not found information.
I thank you for your help.
DuaneB
The leds are only showing the values of the analogReads so you just need to add the following -
Code: [Select]
  // read in the inputs
  syncPhaseInc = mapPentatonic(analogRead(SYNC_CONTROL));
  grainPhaseInc  = mapPhaseInc(analogRead(GRAIN_FREQ_CONTROL)) / 2;
  grainDecay     = analogRead(GRAIN_DECAY_CONTROL) / 8;
  grain2PhaseInc = mapPhaseInc(analogRead(GRAIN2_FREQ_CONTROL)) / 2;
  grain2Decay    = analogRead(GRAIN2_DECAY_CONTROL) / 4;
  // write out the outputs use 5,6,9,10,11 assuming its and UNO
  analogWrite(5,syncPhaseInc);
  analogWrite(6,grainPhaseInc);
  analogWrite(9,grainDecay);
  analogWrite(10,grain2PhaseInc);
  analogWrite(11,grain2Decay);
That should work although I have not tested it.
The Auduino is a great project, lots of people have developed it further by replacing some of the potentiometers with other analog sensors. I have a few examples collected in this post -
Auduino's
http://rcarduino.blogspot.com/2012/08/adding-audio-to-arduino-projects.html
This project is an idea for a modular synthesiser that uses exactly the same hardware as Auduino so if you have an Auduino built, try this code for a different synth, the just upload the Auduino again when you get tired of this one
http://rcarduino.blogspot.com/2012/10/arduino-modular-synthesizer-part-one.html
If your into light and sound these might also be interesting to you -
http://rcarduino.blogspot.com/2012/09/algorithmic-music-on-arduino.html
http://rcarduino.blogspot.com/2012/10/algorithmic-music-visualizer.html
And the must build Illutron B -
http://rcarduino.blogspot.com/2012/08/the-must-build-arduino-project-illutron.html
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
alepom
DuaneB, I thank you very much for the code.
If I have the file auduino_v5.pde, can I add your code before the end of this?
And how are the LEDs physically connected? Have You a simple scheme that I can do?
Thanks a lot for the link that you gave me. I want to make a preamp-synthesizer (using LM386) with the following scheme:
https://www.box.com/s/h0xogyyc66bkm8ktgzdp
Is it correct?
Thank you very much!
DuaneB
    You should connect the LEDs through 500 Ohm to 1K Ohm resistors to the digital pins numbered - 5,6,9,10,11 one resistor and one led per pin.
    The code goes at the end of your loop function.
Duane B
Read this
then watch this
alepom
Thank you very much, Duane B.
Last question: could you tell me the name of the actions of the individual potentiometers (examples: musical note, wave, frequency, ecc.)?
The reference scheme is this: http://code.google.com/p/tinkerit/wiki/Auduino.
Thank you very, very, very much.
DuaneB
Writing something up now, will let you know when its done.
Duane B
Read this
then watch this
alepom
DuaneB
New section in the middle of this post, its too long and needs to be rewritten to be shorter and clearer, but it might answer your question, if not let me know and I will take it into account when I rewrite the section -
Duane B
Read this
then watch this
alepom
Thanks Duane B,
but I wanted to know the name of the 5 controls (http://code.google.com/p/tinkerit/wiki/Auduino). I need it to write the names on the box of the synthesizer.
A pot, for example, I think it's the pitch, but what input corresponds in arduino (0, 1, 2, 3, or 4)?
And what is the name of the other 4 controls? Ad what are the corresponding Arduino input?
DuaneB
Its already there in the code -
Code: [Select]
  syncPhaseInc = mapPentatonic(analogRead(SYNC_CONTROL)); // pitch
  grainPhaseInc  = mapPhaseInc(analogRead(GRAIN_FREQ_CONTROL)) / 2; // grain/triangle wave 1 frequency
  grainDecay     = analogRead(GRAIN_DECAY_CONTROL) / 8;                   // grain/triangle wave 1 decay
  grain2PhaseInc = mapPhaseInc(analogRead(GRAIN2_FREQ_CONTROL)) / 2; // grain/triangle wave 2 frequency
  grain2Decay    = analogRead(GRAIN2_DECAY_CONTROL) / 4;                    // grain/triangle wave 2 decay
Duane B
Read this
then watch this
alepom
Thank you very much Duane B!
I would like to achieve, with a button and a LED display, a switch of musical scales.
The switch practically initializes syncPhaseInc as mapPentatonic(analogRead(SYNC_CONTROL)) or mapMidi(analogRead(SYNC_CONTROL)); or mapPhaseInc(analogRead(SYNC_CONTROL)) / 4;.
Are there  other types of musical scales that I can enter?
DuaneB
Why not just plug in a cheap kids keyboard and play whatever you want. This is not running Auduino yet, but I plan to have it running Auduino at some point this week -
http://rcarduino.blogspot.com/2012/10/five-dollar-synthesiser.html
Duane B
Read this
then watch this
alepom
I have a cheap keyboard at home, but I'm not so good with electronics :)
For this reason, I would like to change the arduino synth adding other scales / shades.
You can explain how to obtain them?
Thank you very much.
DuaneB
Not me, you need a musician for that, but you will find that the original pentatonic is the best sounding, the others are all very plain in comparison.
Duane.
Read this
then watch this
