Topic: [SOLVED] How to set time on DS1307 using Time library? (Read 94527 times) previous topic - next topic
bratan
Oct 25, 2012, 03:12 am Last Edit: Oct 29, 2012, 09:53 pm by bratan Reason: 1
I'm trying to set time on DS1307 chip via Time library, but can't figure out how to do it. I successfully changed Arduino's time with setTime(hr,min,sec,day,month,yr) but it doesn't propagate to RTC chip :(
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, etc.
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
JChristensen
There is a second library that comes with the Time library, called DS1307RTC. Once the system time is set, all that is needed is a call to RTC.set():
Code: [Select]
#include <Time.h>
#include <DS1307RTC.h>
#include <Wire.h>
setTime(hr,min,sec,day,month,yr);
RTC.set(now());
arghduino
from adafruit:
Code: [Select]
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup () {
    Serial.begin(57600);
    Wire.begin();
    RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
    DateTime now = RTC.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now.unixtime() + 7 * 86400L + 30);
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    delay(3000);
bratan
Thanks guys!
It's basically example code "RTC" from Time library examples.
RTC.set(now()); sounds like what I'm looking for, thanks Jack!
arghduino, I've tried Ada's example before, it doesn't set my RTC's chip time for some reason. I posted on adafruit forum, and they say it's because I'm not using their kit, which is true, but I don't see how it matters since I'm using same DS1307 chip.
JChristensen
Hmmmm, that's odd, I wouldn't think you'd have to use their RTC kit either. I have several of their RTCs and they work fine with the Time.h and DS1307RTC.h libraries. I think I may have tried Ada's library in the past, and I don't remember any problems, but for whatever reason I just stick with Time.h and DS1307RTC.h. Time.h has a lot of functionality which I like. DS1307RTC.h also will work with a DS3231 (Chronodot).
bratan
Thanks again Jack!
This totally worked!
Code: [Select]
RTC.set(now());
Yeah I'm at loss why Adafruit's library is not setting time on my chip. BTW I found this great and super simple code online that sets time just fine without any library:
Code: [Select]
//Arduino 1.0+ Only
//Arduino 1.0+ Only
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
void setup(){
  Wire.begin();
  setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
  printDate();
void setDateTime(){
  byte second =      00; //0-59
  byte minute =      19; //0-59
  byte hour =        21; //0-23
  byte weekDay =     4; //1-7
  byte monthDay =    27; //1-31
  byte month =       10; //1-12
  byte year  =       12; //0-99
  Wire.beginTransmission(DS1307_ADDRESS);
  Wire.write(zero); //stop Oscillator
  Wire.write(decToBcd(second));
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));
  Wire.write(decToBcd(weekDay));
  Wire.write(decToBcd(monthDay));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.write(zero); //start
  Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)  {
// Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
void printDate(){
  // Reset the register pointer
  Wire.write(zero);
  Wire.requestFrom(DS1307_ADDRESS, 7);
  int second = bcdToDec(Wire.read());
  int minute = bcdToDec(Wire.read());
  int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  int monthDay = bcdToDec(Wire.read());
  int month = bcdToDec(Wire.read());
  int year = bcdToDec(Wire.read());
  //print the date EG   3/1/11 23:59:59
  Serial.print(month);
  Serial.print("/");
  Serial.print(monthDay);
  Serial.print("/");
  Serial.print(year);
  Serial.print(" ");
  Serial.print(hour);
  Serial.print(":");
  Serial.print(minute);
  Serial.print(":");
  Serial.println(second);
JChristensen
While libraries are great because they simplify the mainline code, it's very much worthwhile to understand some of what's under the covers, in this case, using I2C to interface to the RTC chip directly. So if there is a problem, or a feature of the chip that the library doesn't implement, you can do it yourself. In the case of the DS1307RTC library, for example, it doesn't implement any methods to interface to the DS1307's static RAM.
Also note the layers of libraries here. DS1307RTC depends on both the Time library and the Wire library. The code from bildr only requires the Wire library. It could be taken one step further, and the ATmega328's registers could be manipulated directly to do the I2C communication, and then the Wire library could be eliminated.
Glad you got it working!
larryd
Warning:    Your "code online" link causes:
2012-11-19 12:44:12,High,An intrusion attempt by 129.121.36.98 was blocked.,Blocked,No Action Required,Web Attack: Malicious Toolkit Website 9,No Action Required,No Action Required,"
With Norton antivrus from my computer.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
franlol
Mubashirpmc
hanafiahgunawan99
look my video... https://www.youtube.com/watch?v=gQOWvMCIF2E
and this my code
#include "Wire.h"
#define DS3231_I2C_ADDRESS 0x68
  return( (val/10*16) + (val%10) );
  return( (val/16*10) + (val%16) );
  Wire.begin();
  // set the initial time here:
  // DS3231 seconds, minutes, hours, day, date, month, year
  //setDS3231time(0,52,19,3,8,5,18);
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte dayOfMonth, byte month, byte year)
  // sets time and date data to DS3231
  Wire.beginTransmission(DS3231_I2C_ADDRESS);
  Wire.write(0);
  Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
  Wire.write(decToBcd(dayOfMonth));
  Wire.write(decToBcd(month)); // set month
  Wire.write(decToBcd(year)); // set year (0 to 99)
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  Wire.write(0); // set DS3231 register pointer to 00h
  Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
  // request seven bytes of data from DS3231 starting from register 00h
  *second = bcdToDec(Wire.read() & 0x7f);
  *minute = bcdToDec(Wire.read());
  *hour = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month = bcdToDec(Wire.read());
  *year = bcdToDec(Wire.read());
void displayTime()
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  // retrieve data from DS3231
  readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
  &year);
  // send it to the serial monitor
  Serial.print(hour, DEC);
  // convert the byte variable to a decimal number when displayed
  Serial.print(":");
  if (minute<10)
    Serial.print("0");
  Serial.print(minute, DEC);
  Serial.print(":");
  if (second<10)
    Serial.print("0");
  Serial.print(second, DEC);
  Serial.print(" ");
  Serial.print(dayOfMonth, DEC);
  Serial.print("/");
  Serial.print(month, DEC);
  Serial.print("/");
  Serial.print(year, DEC);
  Serial.print(" Day of week: ");
  switch(dayOfWeek){
  case 1:
    Serial.println("Sunday");
  case 2:
    Serial.println("Monday");
  case 3:
    Serial.println("Tuesday");
  case 4:
    Serial.println("Wednesday");
  case 5:
    Serial.println("Thursday");
  case 6:
    Serial.println("Friday");
  case 7:
    Serial.println("Saturday");
  displayTime();
