Topic: xbee simple program code for view processing graph (Read 5375 times) previous topic - next topic
nassery
hi. hello everyone here. i'm newbie in both arduino & xbee. i'm currently searching for information about connection for arduino uno board to xbee module & sample program for transmiting analog signal from arduino uno board to receiving xbee to produce a graph view by processing software. basically for analog read from analog input & view a graph by processing software i'm already done. just about the xbee program only i stuck here. it would be glad & my pleasure if u guys can help me. with all, regards. thank you.
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nassery
actually i was working with my wireless ecg project...i have done the programming for analog input from the arduino and i have done the programming on how to view the ecg graph using Processing software at the pc..but for now, i'm stuck at the xbee wireless module program because i dont know how to write a program from the arduino through xbee into my pc..i am using arduino uno..i got the program from the internet for xbee but i dont know how to read the program.. this is the sample program i found... but, basically i don't know how to read the program. bcoz i don't have basic programming. hope u can help me. thank you.
Code: [Select]
* Copyright (c) 2009 Andrew Rapp. All rights reserved.
* This file is part of XBee-Arduino.
* XBee-Arduino is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* XBee-Arduino is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with XBee-Arduino.  If not, see <http://www.gnu.org/licenses/>.
#include <XBee.h>
This example is for Series 1 XBee
Sends a TX16 or TX64 request with the value of analogRead(pin5) and checks the status response for success
Note: In my testing it took about 15 seconds for the XBee to start reporting success, so I've added a startup delay
XBee xbee = XBee();
unsigned long start = millis();
// allocate two bytes for to hold a 10-bit analog reading
uint8_t payload[] = { 0, 0 };
// with Series 1 you can use either 16-bit or 64-bit addressing
// 16-bit addressing: Enter address of remote XBee, typically the coordinator
Tx16Request tx = Tx16Request(0x1874, payload, sizeof(payload));
// 64-bit addressing: This is the SH + SL address of remote XBee
//XBeeAddress64 addr64 = XBeeAddress64(0x0013a200, 0x4008b490);
// unless you have MY on the receiving radio set to FFFF, this will be received as a RX16 packet
//Tx64Request tx = Tx64Request(addr64, payload, sizeof(payload));
TxStatusResponse txStatus = TxStatusResponse();
int pin5 = 0;
int statusLed = 11;
int errorLed = 12;
void flashLed(int pin, int times, int wait) {
    for (int i = 0; i < times; i++) {
      digitalWrite(pin, HIGH);
      delay(wait);
      digitalWrite(pin, LOW);
      if (i + 1 < times) {
        delay(wait);
  pinMode(statusLed, OUTPUT);
  pinMode(errorLed, OUTPUT);
  xbee.setSerial(Serial);
   // start transmitting after a startup delay.  Note: this will rollover to 0 eventually so not best way to handle
    if (millis() - start > 15000) {
      // break down 10-bit reading into two bytes and place in payload
      pin5 = analogRead(5);
      payload[0] = pin5 >> 8 & 0xff;
      payload[1] = pin5 & 0xff;
      xbee.send(tx);
      // flash TX indicator
      flashLed(statusLed, 1, 100);
    // after sending a tx request, we expect a status response
    // wait up to 5 seconds for the status response
    if (xbee.readPacket(5000)) {
        // got a response!
        // should be a znet tx status
    if (xbee.getResponse().getApiId() == TX_STATUS_RESPONSE) {
       xbee.getResponse().getZBTxStatusResponse(txStatus);
       // get the delivery status, the fifth byte
           if (txStatus.getStatus() == SUCCESS) {
            // success.  time to celebrate
              flashLed(statusLed, 5, 50);
            // the remote XBee did not receive our packet. is it powered on?
              flashLed(errorLed, 3, 500);
    } else if (xbee.getResponse().isError()) {
      //nss.print("Error reading packet.  Error code: ");
      //nss.println(xbee.getResponse().getErrorCode());
      // or flash error led
      // local XBee did not provide a timely TX Status Response.  Radio is not configured properly or connected
      flashLed(errorLed, 2, 50);
Binu Madola
hai
  if you have a full functioning Xbee module with  a serial port, you can transfer data as using Serial.print(); function.
for eg.if you have a analog value get from your ecg , as
int x=analogRead(pin);///which analog pin you used
Serial.print(x);
nassery
hai
Serial.print(x);
just serial print function only? just like that? like the program to view the serial monitor? is that so... i try first. i guess juz need to configure the X-CTU only...
Binu Madola
hai,
    What type of BT you are using?
    if you want more serial you must set up a additional softwareserial.
I think you want two one for processing and other for BT.
nassery
i am using xbee as my wireless module..i'm working on programming on how to transmit ecg graph from my arduino to pc via my wireless xbee..
PaulS
Quote
The XBees, when properly configured, replace a wire. There is NOTHING that changes in the programming from when you used a wire to connect the Arduino to the PC.
What, exactly, is an ecg graph?
nassery
owh...so i just configure the xbees..and then just matching it from transmitter and receiver?...do i need to program it in arduino for xbees?
*ecg graph is ELECTROCARDIOGRAPHY which measure our electrical activity of heart...
PaulS
How is this graph stored/represented on the Arduino? What, exactly, are you sending?
Which XBees are you using? Have you get them talking to each other?
How are they connected to the Arduino/PC?
