Topic: Arduino Software not opening in Windows 8 (Read 6215 times) previous topic - next topic
blacksanta_69
Oct 30, 2012, 11:44 pm Last Edit: Oct 31, 2012, 12:12 am by blacksanta_69 Reason: 1
Hi there,
I'm having difficulty opening the Arduino Software - 1.0.1 or 0.23 - on a x64 Windows 8 system. When I run the software the splash screen opens and closes. The program doesn't open following the splash screen.
I've tried running the program in multiple compatibility modes - including Windows SP3 - as an administrator and the result is always the same.
I read on a site that in Windows 7 "disable visual themes" helped a similar sounding issue. (http://www.nerdybynature.com/index.php/2011/10/arduino-ide-crashing-on-windows-7-64-bit/) As near as I can tell there is no equivalent option for Windows 8 - trying "Reduced Color Mode" and "Run in 640x480" doesn't seem to help.
Any insight would be greatly appreciated.
Thanks!
**edit: I've also confirmed that the driver is correctly installed: the arduino DigitalReadSerial sketch (loaded on another system) prints out in hyperterminal.
eried
Can you check if happens the same with: http://arduino.cc/forum/index.php/topic,118440.0.html
I updated almost everything I was able too, JDK, winavr, etc
I still don't move to the final version of Windows (too much stuff to update)
My website: http://ried.cl
kd7eir
Are you trying to open it from the desktop or from the start screen?
blacksanta_69
blacksanta_69
I'll give it a try, thanks.
asarpi
Hi
You should Run as administrator. It's working :)
