Ok let me try to interpret what you write here- I guess that my caculation of the sampling rate is correct -
that the same calculation is used whether I want 4096 samples/s in freqband 1 or I want 40960 samples/s in freqband 0.
So if I let count continue to 40960 as you suggest, what would I expect? I would in theory end up with a 1 hz signal on D13 indicating 40960 samples/s - ok I will try it, but I have seen no activity at all on D13 when the sampling frequency gets over a certain point - I saw that point to be about 5000 samples/s. But I will try!
