Topic: Timer Interrupts on Due (Read 237036 times) previous topic - next topic
henrimontreal
Using this code, you can set a timer for any of the ISRs TC0_Handler through TC8_Handler, see table of parameters below. It is possible to use the timers without a physically mapped pin, such as TC1 channel 0 (TC3_Handler) shown here:
Code: [Select]
volatile boolean l;
//TC1 ch 0
void TC3_Handler()
       TC_GetStatus(TC1, 0);
       digitalWrite(13, l = !l);
void startTimer(Tc *tc, uint32_t channel, IRQn_Type irq, uint32_t frequency) {
       pmc_set_writeprotect(false);
       pmc_enable_periph_clk((uint32_t)irq);
       TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4);
       uint32_t rc = VARIANT_MCK/128/frequency; //128 because we selected TIMER_CLOCK4 above
       TC_SetRA(tc, channel, rc/2); //50% high, 50% low
       TC_SetRC(tc, channel, rc);
       TC_Start(tc, channel);
       tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS;
       tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS;
       NVIC_EnableIRQ(irq);
void setup(){
       pinMode(13,OUTPUT);
       startTimer(TC1, 0, TC3_IRQn, 4); //TC1 channel 0, the IRQ for that channel and the desired frequency
void loop(){
Here is the table of parameters:
ISR/IRQTC        ChannelDue pins
TC0TC002, 13
TC1TC0160, 61
TC2TC0258
TC3TC10none  <- this line in the example above
TC4TC11none
TC5TC12none
TC6TC204, 5
TC7TC213, 10
TC8TC2211, 12
Noob question here, could someone please explain the inputs to the startTimer function? What is channel, and how do we use the frequency input?  Also, what are the pins in the table for?
Can anyone kindly answer to the following question please?
How can we disable the Timer by turning off the PWM? (Outside of Timer Function)
ivanseidel
Code: [Select]
volatile boolean l;
//TC1 ch 0
void TC3_Handler()
void setup(){
       pinMode(13,OUTPUT);
void loop(){
TC0TC002, 13
TC1TC0160, 61
TC2TC0258
TC4TC11none
TC5TC12none
TC6TC204, 5
TC7TC213, 10
TC8TC2211, 12
If it's really needed to understand the code, i suggest you looking at the Datasheet, that is the best place to get those explanations since every uController is different.
But, if you just want to use timers on arduino Due, install the DueTimer library: github.com/ivanseidel/DueTimer
Regards,
Ivan
Arduino DueTimer | https://github.com/ivanseidel/DueTimer
Arduino Thread | https://github.com/ivanseidel/ArduinoThread
ant900
Code: [Select]
volatile boolean l;
//TC1 ch 0
void TC3_Handler()
void setup(){
        pinMode(13,OUTPUT);
void loop(){
TC0TC002, 13
TC1TC0160, 61
TC2TC0258
TC4TC11none
TC5TC12none
TC6TC204, 5
TC7TC213, 10
TC8TC2211, 12
I'm a bit confused about the code for the startTimer function.
-What is the purpose of TC3_Handler() and how does it interact with startTimer()?
-Once startTimer() is called, how do I stop the timer(how do I disable PWM)?
-There's a few lines that I don't understand in startTimer():
Code: [Select]
        TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4); <--- How does TC_Configure() work? Where can I find reference about this?
        uint32_t rc = VARIANT_MCK/128/frequency; <---------- is VARIANT_MCK the frequency of arduino DUE(84MHz)? What does rc do?
        TC_SetRA(tc, channel, rc/2); //50% high, 50% low<----sets the duty cycle?
        TC_SetRC(tc, channel, rc);<---------- what is this line for?
        TC_Start(tc, channel);<---------------enables PWM? How does it work?
        tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS;<----------What does this line do?
        tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS;<--------What does this line do?
        NVIC_EnableIRQ(irq); <-----enables interrupt?
raalst
#93
Apr 21, 2013, 11:14 pm Last Edit: Apr 22, 2013, 11:04 pm by raalst Reason: 1
  StartTimer starts the timer. this function needs to be called once.
  after Starttimer is finished, the (hardware) timer keeps running on it's own, without any need for code.
  the timer counts up to a certain value, then generates an interrupt, starts with 0 and continues counting.
  TC3_handler is called each time the interrupt of Timer/Counter TC3 (=timer 1 channel 0) is generated by the timer.
  "TC3_handler"  is a pre-determined functionname just like "setup" and "loop"
  because TC3_handler is called for each interrupt, it is called as often as the timer hits that "certain value".
  The lower that value the more often the TC3_handler is executed.
Read the datasheet paragraph 37.7.11, fields WAVE, WAVSEL, TCCLKS. TC_configure just sets bits in the TC_CMR register that belongs to TC3 (= Timer 1 channel 0 )
Serial.Println(VARIANT_MCK,DEC) will enlighten. spoiler : yes
rc is the value the timer counts towards. it is that "certain value" I mentioned above.
yes, see datasheet 37.6.11.1, for instance.
it sets the value the timer counts towards. so it defines the frequency of the interrupts generated by the timer
no, it starts the timer. the timer begins incrementing now.
I'm not sure but I think it sets the flag that specifies an interrupt is desired when timer = rc. IER = interrupt Enable Register
IDR = interrupt disable register, all other interrupt-types supported by  TC3 are disabled and will not occur.
yes. it is the overall enabler, allowing interrupts to be generated by TC3.
henrimontreal
#94
Apr 24, 2013, 10:26 pm Last Edit: Apr 24, 2013, 10:35 pm by henrimontreal Reason: 1
Code: [Select]
volatile boolean l;
//TC1 ch 0
void TC3_Handler()
void setup(){
       pinMode(13,OUTPUT);
void loop(){
TC0TC002, 13
TC1TC0160, 61
TC2TC0258
TC4TC11none
TC5TC12none
TC6TC204, 5
TC7TC213, 10
TC8TC2211, 12
Guys! can anyone kindly explain me why this code does not work for the frequencies upper than 3 KHZ?
I have tested 1Hz to 3000Hz for the frequency but seems further frequencies it has problem.
What's the acceptable range of frequency?
We did a loop as follows.
  startTimer(TC1, 0, TC3_IRQn, 1);
  Serial.println("1Hz");
 delay(5000);
  startTimer(TC1, 0, TC3_IRQn, 4000);     //  LIne 6
   Serial.println("4KHz");
 delay(3000);
This frequency is used to control the speed of motor.
When we set the second frequency (Line 6 ) to 4000HZ it won't return to the 1HZ as it is supposed to.
We tried 1 to 3KHZ and it works but more than 4KHZ it goes weird!
Any solution please?
ant900
I got frequency between 1-21KHz to work, but I found another problem. I can't get 2 timers to run simultaneously. I ran the startTimer function twice with different handlers, but they refuse to work. Anyone know how to fix this problem?
ivanseidel
Try using my Library: https://github.com/ivanseidel/DueTimer
It has everything implemented, revised, and checked... (It's not PERFECT, but if you find any bugs, fell free to notify me!)
Touf2638
I tried to use your librairie and it works until 4 us. Under it don't works. On scope I have 2.6us for 2 asked. For 4us I have 4us so it's ok.
It's not possible to put 2 ?
Thanks
Touf2638
Sorry,
I use digitalwrite for my tests instead use port directly and digitalwrite take time  :smiley-roll-blue:
So it works thanks.
cdan
Hello everybody.
I am trying to generate a square wave using timer counters but I do not want to use an interrupt, rather I would like to output to go directly to TIOA0. I have the following configuration of the registers
http://paste.ubuntu.com/5703102/
but I get no output on pin 2 of Arduino Due.
What am I missing?
Best regards,
Dan.
cdan
Found the bug:
Code: [Select]
  TC_Configure(chTC, chNo,
       TC_CMR_TCCLKS_TIMER_CLOCK4 |
       TC_CMR_WAVE |         // Waveform mode
       TC_CMR_WAVSEL_UP_RC | // Counter running up and reset when equals to RC
       TC_CMR_ACPA_SET |     // RA compare sets TIOA
       TC_CMR_ACPC_CLEAR );  // RC compare clears TIOA
I have to set TC_CMR_ACPA_SET and TC_CMR_ACPC_CLEAR to instruct the counter to change the level on PIOA0 when the counter's value has reached RA/RC
AndiJay
Where exactly is a function like TC_Configure() or TC_GetStatus() actually defined? Right now, I'm just trying to figure out how to write to specific registers in the Arduino IDE. I may need to do this to change the frequency of a PWM.
cdan
If you include #include <Arduino.h> you should have access to them.
The source code can be found in:
arduino-1.5.2\hardware\arduino\sam\system\libsam\include\tc.h
arduino-1.5.2\hardware\arduino\sam\system\libsam\source\tc.c
AndiJay
I see I see,
Where all all the structs defined? Like tc->xxxx?
Thanks
cdan
Everything is there. Just do a grep (or file search if not on a *nix os).
The source files even have some comments. You should also have the SAM3X8E datasheet at hand too.
