Topic: how to create robot car with sensor temp ?? (Read 2360 times) previous topic - next topic
Alarick
i was there to make a robot car project using arduino with temp.sensor....
can anyone help what kind of tools and code program???
PaulS
With a temporary sensor? Wouldn't a permanent one make more sense?
can anyone help
Sure. I'll be right over. Where do you live?
what kind of tools
A chainsaw and an ox-acetelene torch, to start with. A CNC mill is almost essential, too.
and code program?
What is the robot car supposed to do?
PaulS
make a robot car fire but use a fan instead of water ...
That's a good idea. If you use water, you'll put the fire out. Using a fan to make it spread is a much better idea. Before long, your whole robot will be burned up, and you can move on to projects that make sense.
Alarick
no no no im sorry for that stetment i was wrong...
my project measure the temperature in the room and if the temperature exceeds the set temperature then the fan will turn on ...
that's it i mean  :)
first i want a motor dc can be set start or stop using arduino....but i don't know the code programm :( can help ?
dxw00d
How is the motor connected? Do you want just on/off or variable speed?
Some references that will be useful:
On/Off - http://arduino.cc/en/Reference/DigitalWrite
Variable speed - http://arduino.cc/en/Reference/AnalogWrite
Alarick
thanks before , but i was try with motor dc is not connected .... what is using transistor ????
