Topic: Clock Choices (Read 2927 times) previous topic - next topic
JoeN
Nov 06, 2012, 06:19 am Last Edit: Nov 06, 2012, 07:12 am by JoeN Reason: 1
Thank you for moving this, I guess it deserved its own thread.
This question concerns the Atmel programmer's fuse options and the fuse choices as listed on the fuse calculator at http://www.engbedded.com/fusecalc/
One thing I have never understood well is the clock choices.  I always use a 16mhz crystal with 2 22pf caps and select the last on the list and it works.  What do the clock selections mean?
Ext. Clock; - true square wave signal?  Applied to which pin?
Int. RC Osc. 8 MHz - OK, I know what this means.
Ext. Low-Freq. Crystal - no idea how this varies from the bottom one.
Ext. Full-swing Crystal - no idea how this varies from the bottom one.
Ext. Crystal Osc. - OK, I get this, but have never seen anyone suggest one other than the 16 mhz crystals.  Some of the chips are rated for 20mhz, do you just use a 20mhz crystal to achieve that?
What do the other values mean, e.g. "Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms;"  Total confusion there.
Would love a quick schooling on these matters if anyone wants to chime in.
Quote
Ext. Clock; Start-up time PWRDWN/RESET: 6 CK/14 CK + 0 ms;
Ext. Clock; Start-up time PWRDWN/RESET: 6 CK/14 CK + 4.1 ms;
Ext. Clock; Start-up time PWRDWN/RESET: 6 CK/14 CK + 65 ms;
Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 0 ms;
Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 4.1 ms;
Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 65 ms;
Int. RC Osc. 128kHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 0 ms;
Int. RC Osc. 128kHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 4.1 ms;
Int. RC Osc. 128kHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 65 ms;
Ext. Low-Freq. Crystal; Start-up time PWRDWN/RESET: 1K CK/14 CK + 0 ms;
Ext. Low-Freq. Crystal; Start-up time PWRDWN/RESET: 1K CK/14 CK + 4.1 ms;
Ext. Low-Freq. Crystal; Start-up time PWRDWN/RESET: 1K CK/14 CK + 65 ms;
Ext. Low-Freq. Crystal; Start-up time PWRDWN/RESET: 32K CK/14 CK + 0 ms;
Ext. Low-Freq. Crystal; Start-up time PWRDWN/RESET: 32K CK/14 CK + 4.1 ms;
Ext. Low-Freq. Crystal; Start-up time PWRDWN/RESET: 32K CK/14 CK + 65 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 258 CK/14 CK + 4.1 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 258 CK/14 CK + 65 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 1K CK /14 CK + 0 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 1K CK /14 CK + 4.1 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 1K CK /14 CK + 65 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 16K CK/14 CK + 0 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 16K CK/14 CK + 4.1 ms;
Ext. Full-swing Crystal; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 0.4-0.9 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 0.9-3.0 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 3.0-8.0 MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 258 CK/14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 1K CK /14 CK + 65 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 0 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 4.1 ms;
Ext. Crystal Osc.; Frequency 8.0-    MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms;
I will never ask you to do anything that I wouldn't do myself.
CrossRoads
Best schooling is to read the data sheet.  Section 9 is clock and start up cycles section.
Then come back & ask again.
http://www.atmel.com/Images/doc8271.pdf
JoeN
#2
Nov 06, 2012, 08:01 pm Last Edit: Nov 06, 2012, 08:04 pm by JoeN Reason: 1
That was all I was asking for and it was extremely informative.  I didn't know that if you used the internal clock you automatically got those GPIO ports freed and got one freed with an external clock.  There were good definitions of why when when to use the different clocking options and what those delays are for.  It answered all my questions.  Thanks again.
Telecommando, thank you too.  I didn't really grasp the difference between full swing and low power crystals and now I am going to do some more research on that topic.
dhenry
All of those can be found in the datasheet.
Quote
Doesn't matter. Applied to XTAL1.
Quote
32Khz. Those other frequencies (typically less than 1Mhz) also work.
Quote
High drive power. Typically for high frequency crystals or noisy environment. More current / power consumption.
Quote
Yes, you can use other frequencies as well - from DC to whatever specified. Overclocking is also possible - I have ran them at 32Mhz no problem.
