Topic: How do I connect a 172719 jameco relay? (Read 1 time) previous topic - next topic
zeami
Nov 06, 2012, 08:21 pm Last Edit: Nov 06, 2012, 08:26 pm by zeami Reason: 1
Anyone knows how to connect a relay?
I need to turn on and off fans that work at 120 volt. For that I need to use the jameco 172719 relay, so now I have one but I dont know how to connect things: I donĀ“t know where to plug the interrupted 120 V cable and where to plug what goes to the pin of the arduino and if it needs 5V or some other current aside of the 120V
interrupted one. I attached an image with the wiring diagram printed on top of it and
the info printed on the side.
Many thankssss!
JoeN
#1
Nov 06, 2012, 08:31 pm Last Edit: Nov 06, 2012, 08:35 pm by JoeN Reason: 1
You are going to need a transistor to switch the relay and a protection diode to protect the Arduino.  The playground has some sample schematics.  I would test this out with the relay switching low voltage DC (5-12V) to a lamp or LED so that I had a good understanding of how the circuit was behaving before I hooked the circuit up the mains.
http://www.arduino.cc/playground/uploads/Main/relays.pdf
http://www.arduino.cc/playground/uploads/Learning/Arduino_Opto_relay.pdf
I will never ask you to do anything that I wouldn't do myself.
zeami
Many thanks, I followed your instructions and it works perfect!
JoeN
To be fair, I only pointed you to a tutorial someone else wrote.  Following tutorials like those are how I learned to do what I have been able to do so far.  There are a lot of good teachers on the Internet and around here especially.
