Topic: [HELP] java + arduino and servo (Read 2153 times) previous topic - next topic
wiicaak
Some body help me please..
I am a nubi in arduino..
I need to use an arduino uno board to control 2 motor servo,with java application,
I had bought the arduino and the servo, is there somebody can help me with source code on arduino and java?
And how i put the two servo on arduino board?  :~
Regards;
AWOL
Have you looked at Processing?
Have you looked at any of the worked examples?
(I deleted your other post on this subject to save other people wasting their time)
wiicaak
Of course i had, but i not too understand, sorry for my useless post,
i just wanna to understand about an arduino with java and motor servo..
zoomkat
Simple servo test code for servo testing.
Code: [Select]
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
wiicaak
hai zoomkat..
many thanks for your comment, is this sketch will recieve the serial data from java?
which part of this sketch accepting data from java??
zoomkat
hai zoomkat..
The code will receive data from most any application (java, VB, or whatever) that outputs the appropriate rs232 based serial communication.
wiicaak
when i sending data to arduino from java, what kind of data type i have to send?
zoomkat
Ascii characters. Start testing by using the serial monitor. Java questions probably should be posted in a java forum for best answers.
