Topic: Using Arduino Leonardo as MIDI device (Read 7409 times) previous topic - next topic
Hansibassi
Hello everyone
Is it possible, to use the Arduino Leonardo out-of-the-box as a MIDI device?
I can see, that the Leonardo has built-in USB communication, and a built-in feature of behaving as a USB-HID device.
Doesn't that mean, that it can appear as a MIDI device as well, without the need to flash the firmware, like I have to with the UNO?
I've already succesfully turned my Uno rev3 into a MIDI-device with the HIDUINO firmware, but I'm wondering if this could be achieved easier with the Leonardo board?
johnwasser
I don't think anyone has written a MIDI library for the Leonardo yet.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
Thot
There are three kind of people in the world: Those who can count, and those who can't
Hansibassi
#Johnwasser Okay, too bad
#Thot, No it has to act as a real MIDI-device, since I'm planning to use it with an iPad, but thanks anyway :)
bjtliveset
There isn't a way to control the midi protocol from arduino leonardo without using any program that does to MIDI converter SERIAL?
johnwasser
You should be able to emulate a USB MIDI device with the Leonardo but unless you can find someone who has done it already you will be the first and therefore will have to do it all yourself.
Here is a document to get you started:
http://www.usb.org/developers/devclass_docs/midi10.pdf
bjtliveset
Thanks john. I will begin to study this document.
Qbert
Any news? I would like to let Leonardo be recognized as HID (MIDI) device.
Nantonos
No, it would be harder.
If you want an out of the box MIDI device that is Arduino compatible, Teensy (2.0, ++, and 3.0) have native MIDI-over-USB.
jaydog
This is kind of frustrating. I wish I knew more about the Leonardo HID architecture. Someone already listed the spec above on USB MIDI and it's actually pretty straightforward. The problem is that HID functions don't seem to be easy to get at without some serious hacking. I don't know where I'd begin on this. It seems pretty easy to send HID data (HID_SendReport) but not so easy to register a device... Is anyone on the development team working on this? Seeing as there's already Keyboard and Mouse implemented, it probably wouldn't be a huge project for someone who already understands how to set up an HID driver/register an HID device...? Anyone want to post a little information with where one might try to start on this?
Daylen
Hi There!
I have had exactly the same problem for the last two days with an arduino leonardo. Very frustrating. But finally I found a solution:
1.) I am using the program Hairless (http://projectgus.github.com/hairless-midiserial/)
      ---it convers Serial to midi output
2.) In addition I use LoopBee1 (http://loopbe1.softonic.de/download (a german site, but You propably can find it on an english  one too))
      ---this software turns midi output from one program into a "real" midi device, wich can feed any other program with real midi.
both are totally free softwares.
I hope this helps as much as it helped me,
Daylen
