Topic: Due pinout diagram (Read 503027 times) previous topic - next topic
kvadrug
Thank you for very helpful diagram.
Almost all pins are marked as digital. Does it mean that I can use all of them with digitalRead/Write and interrupts?
christian_oei
hi all
I have a project to read PT-100 using arduino due. but the problem is the bit value from analog is not constant
I hope someone from this forum can give me some explanation
australianoz
The editable pdf is fantastic. Thanx mate. Much appreciated your work. Top notch
eliascor
Hi Graynomad :)
What application did you use for drawing the diagram?
It looks nice, thanks.
hibaS128
bonjour
comment on rajoute l'atmegaS128 sur mini.menu.cpu ? merci
BillyHagen
Thanks for the creation! Your work is truly great! I presuppose that you are a genius:)
danish_1419
Can anyone please help me out with the method of connecting arduino due board with LMP91000evm.
LMI1
Information about DUE SPI is confusing. One problem I found today is in the schematic. MOSI text is on the + 5V pin. In this link https://www.arduino.cc/en/Reference/SPIit is correct I hope. All this creates a lot of posts.
Hello, I am new to here, appreciate if any gent knows the right ling to the 'DUE Pin Diagram'. I see the links on the first page of this thread is gone...
Thanks in ahead.
Chy
Hester74
Links to pinouts not working. Please fix.
ard_newbie
Since the links provided by Graynomad come from his own site (www.robgray.com), you should email him directly on his web site.
graynomad
I have just been alerted to the fact that all the links are broken. I recently had to clean up my server and it seems that there was some collateral damage :(
Unfortunately the files in question are NOT in my backed up data, why I have no idea, but I'll try to find versions in other locations and re-instate them.
SYEDFAIZAN
hello guys!
i am connecting arduino due i2c1 with my dac mcp4725 but dnt know how to use i2c1 .its working fine on i2c but i need multiple.
ard_newbie
#178
Dec 20, 2018, 06:52 am Last Edit: Dec 20, 2018, 06:52 am by ard_newbie
This is not the right place to post this thread (no link with the Graynomad pinout diagram). Ask the mod to transfer your post to the DUE threads.
graynomad
#179
Dec 20, 2018, 12:25 pm Last Edit: Dec 20, 2018, 12:25 pm by graynomad
I think that all files except Gogol's editable version have been restored. I can't find Gogol's file anywhere, if he's still a member maybe he has a copy.
