Topic: [HELP] Servos and comparators (Read 1 time) previous topic - next topic
Gin319
Guys, I'm currently developing a code for my project, that basically turns a servo a certain number of degrees, by a corresponding pulse from the comparator circuit that i built. It is working fine, along with the reactions, but there is one problem, as there is a continuous pulse on the input of the arduino, it turns the servo, but, it goes back and forth to the desired position, making it move quite a lot, rather than staying put on the position. How to eliminate this? Here's a copy of the code.
Code: [Select]
#include <Servo.h>
Servo MainS;
int pos = 90;
int L = 12;
int C = 11;
int R = 10;
  MainS.attach(8);
  pinMode(L, INPUT);
  pinMode(C, INPUT);
  pinMode(R, INPUT);
  int Ls = digitalRead(L);
  int Cs = digitalRead(C);
  int Rs = digitalRead(R);
  if (Ls == 1) {
      for(pos = 90; pos <= 179; pos += 5)
          MainS.write(pos);
          delay(15);
  if (Rs == 1) {
      for(pos = 90; pos >=0; pos -= 5)
          MainS.write(pos);
          delay(15);
  if (Cs == 1) {
        pos = 90;
        MainS.write(pos);
      delay(15);
johnwasser
When the L or R pin is on you tell it to move to 90 and then in steps to either 0 or 179.  If you don't want it to move to 90 you could track the current position and move from there:
Code: [Select]
int position = 90;
  if (Ls == 1) {
      for(pos = position; pos <= 179; pos += 5)
          MainS.write(pos);
          delay(15);
      position = 179;
  if (Rs == 1) {
      for(pos = position; pos >=0; pos -= 5)
          MainS.write(pos);
          delay(15);
      position = 0;
  if (Cs == 1) {
        pos = 90;
        MainS.write(pos);
        position = 90;
      delay(15);
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Gin319
Thanks for help. It is working! :D
Gin319
I have modified the code, and i would like to get the last state of the sensor, in this case, when it turns 1 1 1 1 1, the uC will follow the last state it was in...
Here's the code
Code: [Select]
//Code by O.L.
#include <Servo.h>
Servo MainS;
int pos = 90;
int LM = 13;
int L = 12;
int C = 11;
int R = 10;
int RM = 9;
int position = 90;
  MainS.attach(8);
  pinMode(LM, INPUT);
  pinMode(L, INPUT);
  pinMode(C, INPUT);
  pinMode(R, INPUT);
  pinMode(RM, INPUT);
int LMs = digitalRead(LM);
int RMs = digitalRead(RM);
if (LMs == 0 && Ls == 0 && Cs == 0 && Rs == 0 && RMs == 0){
   pos = 90;
        MainS.write(pos);
        position = 90;
if (LMs == 0 && Ls == 1 && Cs == 1 && Rs == 1 && RMs == 1) {
          MainS.write(pos);
          delay(15);
      position = 179;
if (LMs == 1 && Ls == 1 && Cs == 1 && Rs == 1 && RMs == 0) {
          MainS.write(pos);
          delay(15);
      position = 0;
if (LMs == 1 && Ls == 1 && Cs == 1 && Rs == 0 && RMs == 1) {
      for(pos = position; pos >=45; pos -= 5)
          MainS.write(pos);
          delay(15);
      position = 45;
if (LMs == 1 && Ls == 0 && Cs == 1 && Rs == 1 && RMs == 1) {
      for(pos = position; pos >=135; pos -= 5)
          MainS.write(pos);
          delay(15);
      position = 135;
if (LMs == 1 && Ls == 1 && Cs == 0 && Rs == 1 && RMs == 1) {
        pos = 90;
        MainS.write(pos);
        position = 90;
if (LMs == 1 && Ls == 1 && Cs == 1 && Rs == 1 && RMs == 1) {
        pos = position;
        MainS.write(pos);
        position = 90;}
johnwasser
Code: [Select]
        pos = position;
        MainS.write(pos);
        position = 90;}
Two things:
   1) If you want it to maintain the same position, don't change position to 90.
   2) The servo will maintain position until you tell it otherwise.
If you eliminate the un-needed assignment (1):
Code: [Select]
        pos = position;
        MainS.write(pos);}
If you then eliminate the un-needed write (2):
Code: [Select]
if (LMs == 1 && Ls == 1 && Cs == 1 && Rs == 1 && RMs == 1) {  }
Now that the if-statement is empty you can eliminate that, too:
Code: [Select]
// In the case of (LMs == 1 && Ls == 1 && Cs == 1 && Rs == 1 && RMs == 1) we don't need to do anything.
