Topic: Help Finding LED Diffusion Cap (Read 2254 times) previous topic - next topic
xiwi
I'm having trouble finding a specific part. It's a cap that sits snuggly on top of a 5mm LED. It's semi-transparent and acts as diffusion for the LED.
At the top there's also a little bump in the center. As if it had been ripped from another piece of plastic. Tried to show this in my drawing.
Here's a photo of it mounted on a faceplate
http://imgur.com/Usdvy,MgQx5#1
... and a shot from the back
http://imgur.com/6iWST
And here's my diagram of what the part actually looks like.
Is anyone familiar with it? A link to a website where I could buy it would be SUPER AWESOME.
Thanks!
oric_dan
Led lens or Led mount,
http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&freeText=led+lens&search_type=all
fungus
A thin layer of hot glue works quite well...
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
tkbyd
If you want the LED visible across a wider arc... at the inevitable price, however you achieve it, of at a lower brightness... then all you have to do is use a fine file or similar to flatten the end of the LED.
xiwi
Thanks for the help everyone, but I'm actually building a replica of this device and I need the exact part.
I'm still baffled by it! I've hit up 3-4 electronics forums and no one seems to be able to track it down.
I have a good alternative lined up already using just simple semi-opaque laser-cut acrylic.
But I've added a bunch of neat new tricks to my book for how to diffuse an LED.
Another way is using 400 grit sandpaper or dipped the thing right into some white paint. I wouldn't really recommend either though haha.
fungus
I used to use sandpaper before I discovered hot glue.
Hot glue can be molded, too. Here's an LED 'candle' I made just by adding hot glue to a LED.
(The camera doesn't show it by that's actually a warm-white LED, in real life it's the same color as a candle flame...)
fungus
#6
Nov 30, 2012, 07:28 pm Last Edit: Nov 30, 2012, 08:09 pm by fungus Reason: 1
Did the original use LEDs or lamps? From the apparent age of the original, I'm guessing lamps.
I agree. It looks like it's from a time before LEDs.
The lamps are also a lot bigger than 5mm. Maybe what you need is something like a 10mm diffused off-white LED.
eg.  http://www.ebay.com/sch/i.html?_nkw=10mm+diffused+warm+white+led
Edit: fixed the link...
oric_dan
Try various searches at google images, you can quickly scan over 100s of images, and
may get lucky.
http://images.google.com/
xiwi
From another forum we've decided it's a crimp used by electricians called a butt splice.
The fact that it fits an LED is coincidental.
Still looking for a place to purchase them though.
The diameter is 3/8" at the top.
