Topic: Midi library works fine with PC but poorly with MPC (Read 2417 times) previous topic - next topic
kangs
Dec 08, 2012, 02:08 pm Last Edit: Dec 09, 2012, 11:55 pm by kangs Reason: 1
Hi everybody!
We have developed a little project which understand midi message using midi library and arduino UNO and lights some power leds related with some keys. Our variables are pitch and velocity. The hardware and software work fine when we connect midi wire directly from the computer and send the midi standard. (Cubase 6.5) The problems begin using MPC (AKAI MPC1000). We realized that it uses note on == 0 instead of note off and we have fixed the code, but there are still problems.
At the beginning it works perfectly, but more midi messages are coming more differences occur. At the end leds remain switched on when they must switch off and things like that.
We discard our hardware because works ok connected through the Computer. Is it possible that messages from MPC have any difference else from the midi standard?
This is the example connected through the computer.
http://youtu.be/NnTaYzl1iDM
I hope someone could help us.
We are maintaining the note off in order to use both, Computer and MPC
Code: [Select]
#include <MIDI.h>
int Led2 = 2;
int Led3 = 3;
int Led4 = 4;
int Led5 = 5;
int Led6 = 6;
int Led7 = 7;
int Led8 = 8;
int Led9 = 9;
int Led10 = 10;
int Led11 = 11;
// This function will be automatically called when a NoteOn is received.
// It must be a void-returning function with the correct parameters,
// see documentation here:
// http://arduinomidilib.sourceforge.net/class_m_i_d_i___class.html
void HandleNoteOn(byte channel, byte pitch, byte velocity)
// Do whatever you want when you receive a Note On.
//--------------------**tecla DO central**----------------DIGITAL--------------------------
 if (pitch == 60 && velocity != 0)
   digitalWrite(Led2, HIGH);
 if (pitch == 60 && velocity == 0)
   digitalWrite(Led2, LOW);
//--------------------**tecla RE central**---------------PWM-------------------------------
 if (pitch == 61)
   analogWrite(Led3, 2*velocity);
     //delay(45);
THE REST OF PITCHES....
void HandleNoteOff(byte channel, byte pitch, byte velocity)
 if (pitch == 60)
 if (pitch == 61)
    analogWrite(Led3, LOW);
     //delay(45);
THE REST OF PITCHES
 pinMode(Led2,OUTPUT);
 pinMode(Led3,OUTPUT);
 pinMode(Led4,OUTPUT);
 pinMode(Led5,OUTPUT);
 pinMode(Led6,OUTPUT);
 pinMode(Led7,OUTPUT);
 pinMode(Led8,OUTPUT);
 pinMode(Led9,OUTPUT);
 pinMode(Led10,OUTPUT);
 pinMode(Led11,OUTPUT);
 //pinMode(13, OUTPUT);
 // Initiate MIDI communications, listen to  channel 15
 MIDI.begin(14);
 // Connect the HandleNoteOn function to the library, so it is called upon reception of a NoteOn.
 MIDI.setHandleNoteOn(HandleNoteOn);  // Put only the name of the function
 MIDI.setHandleNoteOff(HandleNoteOff);  // Put only the name of the function
 // Call MIDI.read the fastest you can for real-time performance.
 MIDI.read();
 /*digitalWrite(13, HIGH);   // set the LED on
 delay(400);              // wait for a second
 digitalWrite(13, LOW);    // set the LED off
 delay(400);              // wait for a second*/
 // There is no need to check if there are messages incoming if they are bound to a Callback function.
robtillaart
#1
Dec 09, 2012, 09:04 pm Last Edit: Dec 09, 2012, 09:11 pm by robtillaart Reason: 1
Get rid of the delay's in your code, they might cause losing bytes as they are blocking.
You should also post a link to the midi lib you use
Not a root cause, but please keep comments and code in sync otherwise comments make no sense
Code: [Select]
 MIDI.begin(14);
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
kangs
Thanks for the reply!
The library is MIDI 3.2, we found it here --> http://playground.arduino.cc//Main/MIDILibrary
This is complete code running on KUBASE:
Code: [Select]
#include <MIDI.h>
int Led2 = 2;
int Led3 = 3;
int Led4 = 4;
int Led5 = 5;
int Led6 = 6;
int Led7 = 7;
int Led8 = 8;
int Led9 = 9;
int Led10 = 10;
int Led11 = 11;
  if (pitch == 60)
  if (pitch == 61)
      //delay(45);
//--------------------**tecla MI central**----------------DIGITAL--------------------------
  if (pitch == 62)
    digitalWrite(Led4, HIGH);
//--------------------**tecla FA central**---------------PWM-------------------------------
  if (pitch == 63)
    analogWrite(Led5, 2*velocity);
      //delay(45);
//--------------------**tecla SOL central**---------------PWM-------------------------------
  if (pitch == 64)
      analogWrite(Led6, 2*velocity);
      //delay(45);
//--------------------**tecla LA central**----------------DIGITAL--------------------------
  if (pitch == 65)
    digitalWrite(Led7, HIGH);
//--------------------**tecla SI central**----------------DIGITAL--------------------------
  if (pitch == 66)
    digitalWrite(Led8, HIGH);
//--------------------**tecla DO**---------------PWM---------------------------------------
  if (pitch == 67)
    analogWrite(Led9, 2*velocity);
      //delay(45);
//--------------------**tecla RE **---------------PWM--------------------------------------
  if (pitch == 68)
    analogWrite(Led10, 2*velocity);
      //delay(45);
//--------------------**tecla MI**---------------PWM---------------------------------------
  if (pitch == 69)
    analogWrite(Led11, 2*velocity);
      //delay(45);
  if (pitch == 60)
  if (pitch == 61)
      //delay(45);
  if (pitch == 62)
    digitalWrite(Led4, LOW);
  if (pitch == 63)
    analogWrite(Led5, LOW);
      //delay(45);
  if (pitch == 64)
    analogWrite(Led6, LOW);
      //delay(45);
  if (pitch == 65)
    digitalWrite(Led7, LOW);
  if (pitch == 66)
    digitalWrite(Led8, LOW);
  if (pitch == 67)
    analogWrite(Led9, LOW);
      //delay(45);
  if (pitch == 68)
    analogWrite(Led10, LOW);
      //delay(45);
  if (pitch == 69)
    analogWrite(Led11, LOW);
      //delay(45);
  // Initiate MIDI communications, listen to  channel 14
  MIDI.begin(14);
  MIDI.read();
The code running on MPC is exactly the same but we comment all the references to NOTE OFF.
Thank you so much
Sdreoos
Does anybody checked the polyphony? that's, the ability to play two or more notes simultaneously. My prototype didn't  does, I must shift a little bit the timing of notes ...
deseipel
one of the things I had to do recently was turn the Thru function off.  That helped my project.
The only other thing I could think of would be that the MIDI buffers are getting full?
I'd use MIDI OX, plug the mpc directly to the PC and look at the data it's sending.  MIDI timing messages may be eating up your buffer space.
That's just a shot in the dark, I'm not sure if that's it or not.
kangs
Thanks for replies...
There are some customized settings in the midi 3.2 library. It is configured as follow:
Code: [Select]
#define COMPILE_MIDI_IN         1           // Set this setting to 1 to use the MIDI input.
#define COMPILE_MIDI_OUT        0           // Set this setting to 1 to use the MIDI output.
#define COMPILE_MIDI_THRU       0           // Set this setting to 1 to use the MIDI Soft Thru feature
                                            // Please note that the Thru will work only when both COMPILE_MIDI_IN and COMPILE_MIDI_OUT set to 1.
#define USE_SERIAL_PORT         Serial      // Change the number (to Serial1 for example) if you want
                                            // to use a different serial port for MIDI I/O.
#define USE_RUNNING_STATUS 0 // Running status enables short messages when sending multiple values
                                            // of the same type and channel.
                                            // Set to 0 if you have troubles with controlling you hardware.
#define USE_CALLBACKS           1           // Set this to 1 if you want to use callback handlers (to bind your functions to the library).
                                            // To use the callbacks, you need to have COMPILE_MIDI_IN set to 1
#define USE_1BYTE_PARSING       1           // Each call to MIDI.read will only parse one byte (might be faster).
// END OF CONFIGURATION AREA
// (do not modify anything under this line unless you know what you are doing)
#define MIDI_BAUDRATE 31250
#define MIDI_CHANNEL_OMNI 0
#define MIDI_CHANNEL_OFF 17 // and over
#define MIDI_SYSEX_ARRAY_SIZE 255 // Maximum size is 65535 bytes.
We are thinking with this parameters just the MIDI IN is working. Perhaps isn't enough.
We are going to test a monophonic sequence in order to check the polyphony thing.
About the MIDI buffer space, long time ago we check a simple single sequence and it seems good (I attach the results...)
