Topic: using the PS2 keyboard library with Arduino Leonardo (Read 2458 times) previous topic - next topic
_mattb
I'm having difficulties getting the PJRC PS2 keyboard library (http://www.pjrc.com/teensy/td_libs_PS2Keyboard.html) working reliably with the Arduino Leonardo. I'm relatively new to using the Arduino, but this library seems to be the recommended way to read PS2 keystrokes.
When I run the example sketch to echo keystrokes to the serial terminal, I get about 50% of the characters echoed correctly. The other half typically consists of random characters. In addition, I'd say only 30% of the keystrokes are actually detected at all. I tested many keys on the keyboard to see if there was a mechanical fault but this mis-identification and detection lag happened to all of them.
I get very different results using code from this blog which just implements the PS2 protocol in a barebones way: http://nocommercialpotential.posterous.com/interfacing-the-ps2-keyboard . All of the scan codes echoed from this program are consistent (and correct after I manually looked them up) and there is no lag in detection of keystrokes.
So I could implement my own lookup tables with the second example but I'm curious if I'm making a mistake with the PJRC lib. There are more features in that library that I would like to make use of. Thanks for any help.
PaulS
Quote
Recommended by whom? By Paul, on the Teensy? Well that makes sense, so get a Teensy.
_mattb
It's the main hit when you search "PS2 keyboard library arduino."  It's the first thing in the playground: http://playground.arduino.cc/Main/PS2Keyboard  I know that's a public wiki but it clearly works for older Arduino boards..
_mattb
I got the PJRC lib working but in a strange way.  In the example code I define the IRQpin to be pin 3.  However, when I actually wire up the device, I have to connect the keyboard's CLK pin to pin 2 on the Leonardo.  Not 3.  Despite the definition.  This lets the library work as expected.  Connecting to pin 3 results in the gibberish I noted above.
So that's confusing..  More notes and discussion here: http://electronics.stackexchange.com/questions/50911/using-the-ps2-keyboard-library-with-arduino-leonardo
_mattb
I got this working with some slight tweaks to PS2Keyboard.h .  Specifically I had to define the interrupt pins for the Leonardo's ATMega32U4.  My fork is hosted here: https://github.com/yosemitebandit/PS2Keyboard.
