Topic: How does this LED/LED string work? (Read 3163 times) previous topic - next topic
awesomerobot
Dec 11, 2012, 06:55 am Last Edit: Dec 11, 2012, 07:04 am by awesomerobot Reason: 1
I've been trying to figure out this string of battery powered Xmas lights... it's this string specifically http://www.lamplust.com/multi-color-battery-string-lights-wtimer-functions-battery-p-16808.html
I'm a bit new to circuitry in general, but I'm pretty confused about how this string operates -- specifically the fact that there three wires connected to the board with the microprocessor (which controls the blink patterns). Why 3 wires? Why do two share the same terminal on a single LED in this photo? I'm guessing the whole thing is two strings braided together but I just can't wrap my head around how these are wired.
Also, could someone explain to me why when I remove the board between the power source (three AAA batteries) and the lights, and just connect the lights to the power source directly -- nothing works? (I'm still wrapping my head around how transistors work, but I'm guessing I need one in place for the circuit to work?) If I connect a power source and ground to the contacts on a single LED in the string it will light up, but only that one and not the rest it's connected to...
Maybe a full explanation is a lot to ask for, so even being pointed in the right direction would help greatly -- thanks!
fungus
I'm guessing the lights don't all turn on/off at the same time, there's really two or three strings woven together.
Three AAA batteries is only enough to light up two LEDs. The board must have a voltage booster circuit on it to raise the battery voltage to whatever's needed for the LED strings (something like a "joule thief").
Advanced Arduino
awesomerobot
Quote
They do all turn on at the same time, but it definitely seems like at least two strings woven together
Quote
Yeah, I think that's definitely it -- I'm just at the frustrating point where I have a general idea of what to do, but not enough knowledge to know how to do it! I'll get there eventually, Thanks for your help!
