Topic: Use a listener to detect clap from sound module? (Read 2496 times) previous topic - next topic
MarkyMark
All,
I have several sensors and an SPI LCD module hooked up to my Arduino Uno Ethernet and a bunch of code to run during the loop. As a result I am getting results every second over my serial, roughly.
It turns out that the clap sensor (sound module if you like) does not work (it does in a seperate setup and code, not in combination with this setup and code). Three questions:
1 - Could this be caused by the fact that it would be a coincidence that the DigitalRead and the clap intersect?
2 - Can I use a 'listener' that keeps listening my digital input for a clap signal from the module?
3 - Or is there another way to work around this problem?
Thanks a lot for your advice!
Cheers,
MarkyMark
PaulS
Quote
Anything's possible. Although, the intersection between hardware and software is hard to visualize.
Quote
Depends on the module. If it outputs a pulse when it detects a clap, then you could connect it to an interrupt pin, and have it trigger an interrupt.
Quote
Probably.
You'll notice that these answers are about as vague as your questions. What module are you talking about? Where is your code?
MarkyMark
#2
Dec 12, 2012, 08:53 pm Last Edit: Dec 12, 2012, 09:24 pm by MarkyMark Reason: 1
Code: [Select]
*Removed import and define codes*
// Setup ========================================================================================================
void setup(void) {
 //Setup serial cummunication
 //Setting the Arduino I/O ports
 //pinMode(BUTTON, INPUT);
 pinMode(ECHOPIN, INPUT);
 pinMode(TRIGPIN, OUTPUT);
 pinMode(PIR, INPUT);
 pinMode(RELAY, OUTPUT);
 pinMode(RED, OUTPUT);
 pinMode(GREEN, OUTPUT);
 pinMode(BLUE, OUTPUT);
 pinMode(LASER, OUTPUT);
 pinMode(MIC, INPUT);
 //Thermometer =================================================================
 sensors.begin();
 sensors.setResolution(insideThermometer, 12);  // Set the resolution to 12 bit
 //Clock =======================================================================
 Wire.begin();
 RTC.begin();
 if (! RTC.isrunning())
   Serial.println("RTC is NOT running!");
   // following line sets the RTC to the date & time this sketch was compiled
   RTC.adjust(DateTime(__DATE__, __TIME__));
// Main loop ====================================================================================================
void loop(void) {
 // Microphone =============================================================
 int clap = digitalRead(MIC);
 //clap = 0;  // For debugging purposes only
   if(clap == 1)
   digitalWrite(LASER, HIGH);
 if(clap == 0)
   digitalWrite(LASER, LOW);
 Serial.print("Microphone: ");
 Serial.println(clap);
 // Temperature ===========================================================
 sensors.requestTemperatures();
 float tempC = sensors.getTempC(insideThermometer);
 Serial.print("Temperatuur [C]: ");
 Serial.println(tempC);
 if(tempC > CMax)
   CMax = tempC;  // for use on LCD
   Serial.print(" CMax          : ");
   Serial.println(CMax);
 if(tempC < CMin)
   CMin = tempC;  // for use on LCD
   Serial.print(" CMin          : ");
   Serial.println(CMin);
 if(tempC >= 21.0)  // glow red
   digitalWrite(RED, HIGH);
   digitalWrite(GREEN, LOW);
   digitalWrite(BLUE, LOW);
 if((tempC >= 15.0) && (tempC < 21.0))  // glow blue
   digitalWrite(RED, LOW);
   digitalWrite(GREEN, HIGH);
 if(tempC < 15.0)  // glow green
   digitalWrite(BLUE, HIGH);
 // Sonar =================================================================
 // Start ranging
 digitalWrite(LASER,LOW);
 digitalWrite(TRIGPIN, LOW);
 delayMicroseconds(2);
 digitalWrite(TRIGPIN, HIGH);
 delayMicroseconds(10);
 // Compute distance
 float distance = pulseIn(ECHOPIN, HIGH);
 distance= distance/58;
 if (distance > 2500)
   distance = 0;
   Serial.print("Afstand    [cm]: ");
   Serial.println(distance);
 if(distance > 0.0 && distance < 10.00)
 // Clock =================================================================
 DateTime now = RTC.now();
 unsigned long nu = now.unixtime();
 // PIR ====================================================================
 byte moved = digitalRead(PIR);
 if (moved == 1)
   Serial.println("Motion detected!");
   relayAan = (now.unixtime());
   relayUitLang = (now.unixtime() + 30 * 60);  // relay on for 30 minutes
   relayUitKort = (now.unixtime() +  1 * 60);  // relay on for 1 minute
 if((now.hour()) < 7)  // before 7 o'clock
   if(nu <= relayUitKort)
   Serial.print("Time left relay on (<7h)   [s]: ");
   Serial.println(relayUitKort - nu);
   digitalWrite(RELAY, HIGH);  // turn RELAY ON
   if(nu > relayUitKort)
   Serial.println("Relay          : OFF");
   digitalWrite(RELAY, LOW);  // turn RELAY OFF
 if( ((now.hour()) >= 7) && ((now.hour()) < 22) )  // between 7 and 22 o'clock
   if(nu <= relayUitLang)
   Serial.print("Time left relay on (7-22u) [s]: ");
   Serial.println(relayUitLang - nu);
   if(nu > relayUitLang)
 if( (now.hour()) >= 22)  // after 22 o'clock
   Serial.print("Time left relay on (>22h)  [s]: ");
 // LCD ====================================================================
 u8g.firstPage();
 do
   draw(now, weekdays, regel, kolom, distance, tempC, CMin, CMax, moved);
 while( u8g.nextPage() );
 // rebuild the picture after some delay
 //delay(100);
// Screensaver ================================================================
 nSinceStart ++;
 if(nSinceStart % 100 == 0)
   regel ++;
   kolom ++;
   if(regel>4)
     regel = 1;
   if(kolom>2)
     kolom = 0;
// Required Functions ===========================================================================================
// Write to LCD ===============================================================
void draw(DateTime now, String weekdays[], byte regel, byte kolom, float distance, float tempC, float CMin, float CMax, byte moved)
 //DATUM ====================================
 u8g.setFont(u8g_font_5x7);
 u8g.setPrintPos(kolom, 10+regel);
 u8g.print("=");
 u8g.print(weekdays[now.dayOfWeek()]);
 u8g.print(" ");
 u8g.print(now.day(), DEC);
 u8g.print(".");
 u8g.print(now.month(), DEC);
 u8g.print(".");
 u8g.print(now.year(), DEC);
 u8g.print(" ");
 u8g.print(now.hour(), DEC);
 u8g.print(":");
 u8g.print(now.minute(), DEC);
 u8g.print(":");
 u8g.print(now.second(), DEC);
 u8g.print("=");
 //AFSTAND ===================================
 u8g.setFont(u8g_font_7x14);
 u8g.setPrintPos(kolom, 30+regel);
 u8g.print("Afstand: ");
 if(distance == 0)
   u8g.print("-    ");
 u8g.print(distance);
 if(moved==1)
   u8g.print("  *");
 //TEMPERATUUR ===============================
 u8g.setPrintPos(kolom, 45+regel);
 u8g.print("Temperatuur: ");
 u8g.print(tempC);
 u8g.setPrintPos(kolom, 57+regel);
 u8g.print(" Min: ");
 u8g.print(CMin);
 u8g.print(" - Max: ");
 u8g.print(CMax);
// Convert normal decimal numbers to binary coded decimal =====================
byte decToBcd(byte val)
 return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal number ======================
byte bcdToDec(byte val)
 return ( (val/16*10) + (val%16) );
MarkyMark
See your point PaulS, thanks. Hope this will help how I can realize that the clap is detected by the sounds module (http://dx.com/p/arduino-microphone-sound-detection-sensor-module-red-135533), even though the loop takes a bit more then a second (as far as I can detect).
Thanks!
PaulS
Code: [Select]
  clap = 0;
Why bother reading the pin?
I don't see that the clapper is doing anything useful. I'm not sure why it is even connected.
If your loop() function takes a second to execute, with the only delays I see being in the ping sensor code, then the u8g stuff must be what is taking so long.
MarkyMark
Sharp! Did not take the test 'clap = 0;' out before posting the code...
I'd like to be able to turn on the relay by the PIR as well as by clapping.
Datawolf
