Topic: Problem with lmv358 and usb at UNO (Read 6532 times) previous topic - next topic
Arvacon
Hi.
I have an arduino UNO R3 and I was trying to make a laser engraver from cd-rom spare parts, as I read at instructables site (if there is not problem, I can upload the link of the constraction's topic).
But something went wrong at the constraction of the laser drive circuit and it seems it ruined up the arduino. I was using the same ground and power for the whole circuits, for arduino and the laser driver too.
But I did a big mistake that I realized it too late, I had connect the negative output of the laser driver at the common earth, so after a while, as I was trying to upload something at arduino, it became really hot and then the pc turned off. Then I removed arduino and left it to become cold, I turned on my pc again and I tried one more time, but this time arduino was not communicate anymore with the pc and it was becoming hot very fast.
I forgot to tell you that the only part that becomes hot is the lmv358 into 10-15 seconds, that you can't touch it at all, without any load or connected devices at arduino. The arduino seems to start working when you plug in the power socket, the "on" led becomes green and the "L" led blinks for some times, then stops and then it is doing one blink and turn off again. When you push the reset button it happens the same, so does this mean that Atmega328 is working finally?
I am using an external power supply at 12 volts.
Do you have any idea about how to fix this problem? If I change the lmv358, will this make my arduino back to life again or it is more complicated?
I can change it, smd is not problem for me, but I will need your help to determine where is the exact problem, as it might be another component that cause this problem.
I don't know where to start and what to measure to find the problem, so if you drive me about what to measure, I can tell you the results and maybe we can find the faulty parts.
Do you think also that the atmegaU16 might be dead? Is there any way to check this?
And something last.. Nice to meet you guys!  :)
Arvacon
BillO
First, did you try using a different USB port on the PC?
The only things the LMV358 is connected to are the "L" led and the MOSFET.  It is unlikely that the "L" LED is to blame so we are left with the LMV358 and the MOSFET.  If the MOSFET is buggered, it might have taken the 3V3 regulator with it too
So, here's what I'd do.  First I'd make some basic checks.  I made the following measurements on a working UNO R3.
1. Remove the ATmega328 to eliminate it.
2. Connect the external supply (12V) but do not plug the USB cable in.  Connect digital pin 13 to ground. Pin 1 of the LMV358 should be at ~5V.  Pin 3 should be at about 6V and pin 2 at ~3.3V.  Pins 5,6 and 7 should be at 0V and the "L" LED should be off.
3. Connect digital pin 13 to 5V.  Pin 5 should be at ~5V, and pins 6 and 7 should be at ~4.5V and the yellow "L" LED should go on.
If the results of steps 2 and 3 are okay and the LMV358 does not get hot, then it is at least behaving as expected and is likely okay.
Both the gate and the source of the MOSFET should be at 5V.  The drain should not have any appreciable voltage on it.  Mine measure ~0.5V.
The MOSFET is going to be tough to test in circuit, but with no power applied to the Uno, there should be no dead shorts between any of the pins when measured in either direction with a decent DVM.
If the LMV358 measurements and MOSFET check out, the problem is likely the ATmega328.
Anyway, make these checks and let us know the results.
Arvacon
#2
Dec 13, 2012, 11:23 pm Last Edit: Dec 14, 2012, 07:05 am by Arvacon Reason: 1
-Yes I tried different usb ports and also another pc.
-Atmega removed.
-Ground connected with 13 pin.
Results:
pin 1= 4.96V
pin 2= 3.27V
pin 3= 5.46V
pin 4= 1mV
pin 5= 0V
pin 6= 95mV
pin 7= 95mV
pin 8= 4.96V
"L" Led= off
-13pin connected at 5V.
Results:
pin 5= 4.96V
pin 6= 4.5V
pin 7= 4.5V
"L" led= on
-At both steps the LMV358 gets really hot as always.
-That's exactly what I measure at mine too.
-Mosfet seems fine with the DVM, as when you measure a good transistor or diode, so it has not dead shorts at any of the pins.
Dear Billo, first of all thanks for your time, that's exactly what I was mean about help.
So if these components are ok, then what cause the too much heat at lmv358?
I noticed also that the NCP1117 start gets hot too after a while, but not that much as the lmv358.
I took some measurements of this too, but it is confusing me, as I can see, when you measure it from positive or ground pin, you take different results.
Here is the results with the black connector of multimeter at ground.
pin 1= 0V
pin 2= 4.95V
pin 3= 11.33V
tab pin = 4.95V
So what's next? :)
Edit: I corrected a mistype.
retrolefty
Quote
Results:
pin 1= 4.96V
pin 2= 3.27V
pin 3= 5.46V
pin 4= 1mV
pin 5= 0V
pin 6= 95mV
pin 7= 95mV
pin 8= 4.96mV
"L" Led= off
Pin 8 is the Vcc pin for the opamp and should be +5vdc, you show 4.96mV? or is that just a mistype?
Lefty
Arvacon
Oups, sorry my mistake, it's 4.96V  :)
BillO
#5
Dec 14, 2012, 03:14 pm Last Edit: Dec 14, 2012, 03:22 pm by BillO Reason: 1
The only thing I can think of then is that the LMV385 has some internal issue.  It seems to b functioning as is required in the Arduino, but is getting hot.  Either it is consuming a lot of current, or something attached to it is consuming a lot of current.
As far as external things go... Since the LED goes off with digital pin 13 grounded, then the problem does not lie on that output.  You say the FET measures "okay" in circuit, but that does not mean it is behaving properly when power is applied, and it is the only other external device that could be causing the problem.
So, given that the LMV358 appears to be working as expected, I'd say replace the FET as a first attempt.  Before you do that check 2 more things, again with the 328 out of the board:
1)Power the board from the USB cable only, jumper digital pin 13 to ground.  The pins on the LMV328 should read as follows;
  • Pin 1 ~ 0V
  • Pin 2 ~ 3.3V
  • Pin 3 ~ 0V
  • Pin 4 ~ 0V
  • Pin 5 ~ 0V
  • Pin 6 ~ 0V
  • Pin 7 ~ 0V
  • Pin 8 ~ 5V
2) Does the 16U2 get hot at all?
Edit:  BTW, your measurements of the NCP1117 are what you should see.  It appears to be working fine.
SurferTim
lmv358 is U5A on the schematic.
http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
That is the same IC and function as on a Mega IC7.
http://arduino.cc/en/uploads/Main/arduino-mega2560_R3-schematic.pdf
There seems to be a rash of those unlucky users. Here is another with the same problem
http://arduino.cc/forum/index.php/topic,135704.0.html
retrolefty
I was going to offer that this is the second report of a hot op amp on an arduino board recently. Certainly possible a 'bad batch' of the op amps got into a arduino production run? I had never heard of this symptom reported here before in the years I've been here.
Lefty
SurferTim
Quote
If it were a bad batch of lmv358's, I think you would be correct, it would be more prevalent, which it isn't. It appears to be limited to two conditions in common:
1) usb and Vin powered
2) Vin > 11v
retrolefty
Quote
That is not and has never been a problem with the arduino auto-voltage selector circuit. It was designed to be powered from either or both sources attached, that is not the root cause of the problem, there has to be some component failure problem either from manufacture or user caused.
2) Vin > 11v
Again that is well within the board's operating limits and specifications and has never been a problem in the past.
It's an interesting symptom/failure and so far we have not yet determined if there is a common cause to these two reported 'hot op amp' symptom reports or not. A common symptom does not necessarily mean a common cause, further troubleshooting would need to be performed to determine if that is the case or not.
Lefty
Arvacon
#10
Dec 15, 2012, 05:31 am Last Edit: Dec 15, 2012, 06:03 am by Arvacon Reason: 1
  • Pin 1 ~ 0V
  • Pin 2 ~ 3.3V
  • Pin 3 ~ 0V
  • Pin 4 ~ 0V
  • Pin 5 ~ 0V
  • Pin 6 ~ 0V
  • Pin 7 ~ 0V
  • Pin 8 ~ 5V
1)
  • Pin 1 = 107mV
  • Pin 2 = 3.27V
  • Pin 3 = 2.1V
  • Pin 4 = 0V
  • Pin 5 = 0V
  • Pin 6 = 90mV
  • Pin 7 = 90mV
  • Pin 8 = 4.67V
2) Nop, 16U2 doesn't get hot. Even with USB power, lmv358 becomes hot again, but it's at the limits to touch it by hand.
So, do you think that I need change mosfet and lmv358 or there is also something more to check?
If these 2 chips have problem, would this be the reason that 16U2 doesn't communicate with pc anymore?
Edit: I can hear the windows connected sound when I plug in the usb, but I can't see something at the device manager under com ports.
Do you think that I need reprogram the 16U2? Is there any way to read the code of this, to check with this way if the chip needs reprogramming or if it is finally damaged?
BillO
#11
Dec 17, 2012, 09:18 pm Last Edit: Dec 17, 2012, 09:20 pm by BillO Reason: 1
That 2.1V on pin3 is not good with nothing plugged into the Vin.  The LMV358 should be replaced to begin with.
I have had Unos not register before.  Not sure why this happens, but once you get the board working properly you may have to delete the virtual com port and re-register it.  That has worked for me in the past.
Arvacon
Thanks for your help guys.
I will inform you if I have any news.  :)
