Topic: Errors while burning bootloader (Read 32284 times) previous topic - next topic
stamz
I had problems uploading sketches to my Arduino Nano 3.0 compatible board (got verification errors),
so I followed this tutorial: http://arduino.cc/en/Tutorial/ArduinoISP,
using my Arduino Diecimila as a programmer (I've done it before successfully),
and got this error:
avrdude: verification error, first mismatch at byte 0x7800
         0x0c != 0xff
avrdude: verification error; content mismatch
Please see the attached verbose output.
BTW,
I'm using version 1.0.3 of the IDE on Ubuntu 12.10 32bit.
Any ideas?
AverageGuy
This may or may not have any bearing on your problem, but I was unable to burn bootloaders from Ubuntu 10.04 recently.  Everything looked OK but I had similar errors trying to burn and it trashed the chip. When I moved to a Centos 6 system everything started to work fine.  Again, it most likely isn't the same problem, but if you have the ability to use a different OS, it's worth a try.  Might save some time.  Then again, it might waste some time.  ;)
Jim.
stamz
I gave it a try on Fedora 17 x86_64,
and got the same result:
- Program loading on "Diecimila" works.
- Using "Diecimila" to program "Nano" failed on verification stage ("verification error, first mismatch at byte 0x7800").
Thanks anyway.
BTW, before I tried to burn bootloader on "Nano",
it did give me the indication of a working bootloader (that blink after reset), But uploads failed on verification.
Now, it doesn't do that, and it fails on communication when I try to upload.
I know its not completely fried, but guess I've damaged it some how..
spcomputing
Which Nano clone do you have?  I just flashed mine (LISA 2011) with no trouble other that Pin 1 on the ICSP is flipped 180 from where I though it would be.  Another handy tool to see if you have things hooked up correctly is Nick's chip detector:
http://www.gammon.com.au/forum/?id=11633
Same hook-up as the Arduino as ISP.
stamz
I bought this one: http://dx.com/p/arduino-nano-v3-0-81877
I ran the chip detector (actually had to remove md5 code to reduce the size of the binary, in order to upload)
This is the output:
Atmega chip detector.
Entered programming mode OK.
Signature = 1E 95 0F
Processor = ATmega328P
Flash memory size = 32768
LFuse = FF
HFuse = DA
EFuse = FD
Lock byte = FF
Clock calibration = BA
Bootloader in use: Yes
EEPROM preserved through erase: No
Watchdog timer always on: No
Bootloader is 2048 bytes starting at 7800
Bootloader:
7800: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7810: FF FF FF FF 7F FF FF FF FF FF FF FF FF FF FF FF
spcomputing
You are obviously hook-up correctly and your Atmega is talking.  There are a few differences I see between your bootloader and mine:
Code: [Select]
LFuse = FF
HFuse = DA
EFuse = FD
Lock byte = CF
Clock calibration = A4
Also, you are missing code in your bootloader:
Code: [Select]
Bootloader:
7800: 0C 94 34 3C 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C
7810: 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C
7820: 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C
7830: 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C
Try Nick's Atmega Board Programmer and burn the UNO bootloader, then reload the Arduino as ISP to the Diecimila and try burning the Nano 328 again.
http://www.gammon.com.au/forum/?id=11635
stamz
I had to remove stuff to reduce size:
- Includes: bootloader_atmega2560_v2.h, bootloader_atmega1284, bootloader_atmega1280
- signatures: everything except "Atmega328 family"
That's what I got:
Atmega chip programmer.
Written by Nick Gammon.
Signature = 0x1E 0x95 0x0F
Flash memory size = 32768 bytes.
LFuse = 0xFF
HFuse = 0xDA
EFuse = 0xFD
Lock byte = 0xFF
Clock calibration = 0xBA
Bootloader address = 0x7E00
Bootloader length = 512 bytes.
Type 'L' to use Lilypad (8 MHz) loader, or 'U' for Uno (16 MHz) loader ...
Using Uno Optiboot 16 MHz loader.
Type 'V' to verify, or 'G' to program the chip with the bootloader ...
Erasing chip ...
Writing bootloader ...
Committing page starting at 0x7E00
Committing page starting at 0x7E80
Committing page starting at 0x7F00
Committing page starting at 0x7F80
Written.
Verifying ...
Verification error at address 7E00. Got: 0xFF  Expected: 0x11
Verification error at address 7E01. Got: 0xFF  Expected: 0x24
Verification error at address 7E02. Got: 0xFF  Expected: 0x84
Verification error at address 7E03. Got: 0xFF  Expected: 0xB7
Verification error at address 7E04. Got: 0xFF  Expected: 0x14
Verification error at address 7E05. Got: 0xFF  Expected: 0xBE
Verification error at address 7E64. Got: 0xFF  Expected: 0x61
Verification error at address 7E65. Got: 0xFF  Expected: 0xF4
496 verification error(s).
First 100 shown.
Type 'C' when ready to continue with another chip ...
Any chance something is wrong with its Flash/EEPROM?
spcomputing
Quote
Let's see if the Nano will take a EEPROM clear sketch.  Set up your Arduino ISP from the Arduino IDE and then select/upload via programmer Examples->EEPROM->eeprom_clear.  Then try the Burn Bootloader from the IDE.  It worked once for someone else, though I have no idea what the EEPROM does to stuff the SPIEN enable (without disabling the bit).
stamz
I can't upload the eeprom_clear sketch.
Output:
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: reading input file "/tmp/build5476814932130915731.tmp/eeprom_clear.cpp.hex"
avrdude: writing flash (790 bytes):
avrdude: 790 bytes of flash written
avrdude: verifying flash memory against /tmp/build5476814932130915731.tmp/eeprom_clear.cpp.hex:
avrdude: load data flash data from input file /tmp/build5476814932130915731.tmp/eeprom_clear.cpp.hex:
avrdude: input file /tmp/build5476814932130915731.tmp/eeprom_clear.cpp.hex contains 790 bytes
avrdude: reading on-chip flash data:
avrdude: Recv: . [10]
########avrdude: Send: U [55] . [80] . [01]   [20]
avrdude: Recv: . [14]
avrdude: Send: t [74] . [00] . [16] F [46]   [20]
avrdude: Recv: . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff]
## | 100% 0.62s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x0c != 0xff
avrdude: Send: Q [51]   [20]
nickgammon
Can you show a photo of your setup? It looks like the flash is not being updated at all.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
stamz
#10
Dec 18, 2012, 08:30 pm Last Edit: Dec 18, 2012, 08:33 pm by stamz Reason: 1
Sure.
nickgammon
I can't see anything obviously wrong. Can you try shoving a 0.1 uF capacitor between 5V and Gnd on the breadboard, adjacent to where the red and black wires are plugged in? Just a bit more decoupling on the power.
stamz
I don't have one.
Thanks everyone.
I guess I'll just buy a new Arduino.
If you have other ideas, I would like to try them.
Rachana_M
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
Can someone help me with this error rectification? its urgent!!
Leetut
I can't burn bootloader, doing everything correctly, connected correctly, nightmare
Code: [Select]
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): unknown response=0x12
Error while burning bootloader.
