I here some code I found for controlling a DS12887 Microprocessor Bus based RTC... I can't seem to grasp exactly what's going on here... can someone tear it apart and provide a working example for the Arduino?
Thanks!
// Name : ds12887.c //
// Author : Timothy Reitmeyer //
// Notice:
// Date : 05-05-2005 //
// Version: 1.00 //
#define CLK_SECS 0
#define CLK_SECS_ALM 1
#define CLK_MINS 2
#define CLK_MINS_ALM 3
#define CLK_HRS 4
#define CLK_HRS_ALM 5
#define CLK_DOW 6
#define CLK_DOM 7
#define CLK_MON 8
#define CLK_YR 9
#define REGA 10
#define REGB 11
#define REGC 12
#define REGD 13
#define nvram_min 14
#define nvram_max 127
const char dow_text[8][4] =
"Mon",
"Tue",
"Wed",
"Thr",
"Fri",
"Sat",
"Sun"
const char month_text[13][4] =
"Jan",
"Feb",
"Mar",
"Apr",
"May",
"Jun",
"Jul",
"Aug",
"Sep",
"Oct",
"Nov",
"Dec"
struct rtc_pin_def
BOOLEAN cs_bar;
BOOLEAN as;
BOOLEAN rw_bar;
BOOLEAN ds;
BOOLEAN reset_bar;
BOOLEAN irq_bar;
BOOLEAN rclr_bar;
BOOLEAN swq;
int8 ad;
struct rtc_rega_struc
BOOLEAN RS0;
BOOLEAN RS1;
BOOLEAN RS2;
BOOLEAN RS3;
BOOLEAN DV0;
BOOLEAN DV1;
BOOLEAN DV2;
BOOLEAN UIP;
} rega_var;
struct rtc_regb_struc
BOOLEAN DSE;
BOOLEAN MIL;
BOOLEAN DM;
BOOLEAN SQWE;
BOOLEAN UIE;
BOOLEAN AIE;
BOOLEAN PIE;
BOOLEAN SET;
} regb_var;//0b00001100
struct rtc_regc_struc
BOOLEAN bit0;
BOOLEAN bit1;
BOOLEAN bit2;
BOOLEAN bit3;
BOOLEAN UF;
BOOLEAN AF;//1=current time has matched the alarm time.
BOOLEAN PF;
BOOLEAN IRQF;
} regc_var;
struct rtc_regd_struc
BOOLEAN bit0;
BOOLEAN bit1;
BOOLEAN bit2;
BOOLEAN bit3;
BOOLEAN bit4;
BOOLEAN bit5;
BOOLEAN bit6;
BOOLEAN VRT;
} regd_var;
struct rtc_pin_def rtc; //pins for the rtc
struct rtc_pin_def rtc_tris;//tris for the rtc
#byte rtc = 0xF82 //note: no semicolin 0x82=C0 on a 18F452
#byte rtc_tris = 0xF94 //tris location for port C pin 0
#define rtc_tris_r() rtc_tris=0;rtc_tris.ad=0xFF//read data is input
#define rtc_tris_w() rtc_tris=0;rtc_tris.ad=0//write data is output
void init_rtc(void);
char read_rtc(char addr);
void write_rtc(char addr,char data);
void set_time(void);
//C7=swq,6=rclr_bar,5=irq_bar,4=reset_bar,3=ds,2=rw_bar,1=as,0=cs_bar
rtc_tris_w();
rtc.cs_bar=0;//chip active
rtc.ad=addr; //addr is on bus
rtc.rw_bar=0;//write mode
rtc.ds=0; //data strob idle
rtc.as=1; //addr strob
delay_cycles(1); // pause
rtc.as=0; //latch address
rtc.ds=1; //data strob idle
rtc.ad=data; //data is on bus
rtc.ds=0; //latch data
rtc_tris_r(); //set the tris of C and D to ALL INPUTS
char data;
rtc_tris=0b11100000;//set the tris of C for setting address
rtc_tris.ad=0x00; //set the tris of D for setting address
rtc =0b00011110;//set C for for setting address
rtc.ad=addr; //put address on bus
#asm nop #endasm //pause
rtc.as=0; //latch
rtc_tris.ad=0xFF; //set the tris of D for reading data
rtc.ds=0; //release
data=rtc.ad; //read the data from the bus
rtc_tris_r(); //set the tris of B and D to ALL INPUTS
return(data);
void init_rtc()
rtc_tris.reset_bar=0;//set the tris of C
rtc.reset_bar=0; //reset
delay_ms(200);// delay the required time for reset
rtc.reset_bar=1; //release
rtc_tris_r(); //set the tris of C & D to ALL INPUTS
while(rega_var.UIP);//wait for update to finish
regd_var=read_rtc(REGD);
if(regd_var.VRT) fprintf(DEBUG,"Lithium battery OK\n\r");
else fprintf(DEBUG,"Lithium battery dead\n\r");
rega_var=0;
write_rtc(REGA,0b11110100); //set reg A
write_rtc(REGB,0b11111100); //(msb) SET,PIE,AIE,UIE,SQWE,DM,MIL,DSE (lsb)
void set_time()
char yr, mn, dt, dy, hr, min, sec;
char input[10];
regb_var=read_rtc(REGB);
if(regb_var.DM=1) /* Binary data */
fprintf(DEBUG,"\nEnter the year (0-99): ");
fgets(input,DEBUG);//scanf("%bd", &yr);
yr=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",yr);
fprintf(DEBUG,"Enter the month (1-12): ");
fgets(input,DEBUG);// scanf("%bd", &mn);
mn=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",mn);
fprintf(DEBUG,"Enter the date (1-31): ");
fgets(input,DEBUG);// scanf("%bd", &dt);
dt=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",dt);
fprintf(DEBUG,"Enter the day (1-7): ");
fgets(input,DEBUG);// scanf("%bd", &dy);
dy=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",dy);
if(regb_var.MIL=1) /* if 24 hour mode */
fprintf(DEBUG,"Enter the hour (1-23): ");
fgets(input,DEBUG);//scanf("%bd", &hr);
hr=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",hr);
fprintf(DEBUG,"Enter the hour (1-11): ");
hr=atoi(input);
fprintf(DEBUG,"A)M or P)M (A/P) " );
fgets(input,DEBUG);//scanf("%1bs", &min);
if(input == 'P' || input == 'p')
hr |= 0x80; /* add PM indicator */
fprintf(DEBUG,"Enter the minute (0-59): ");
fgets(input,DEBUG);//scanf("%bd", &min);
min=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",min);
fprintf(DEBUG,"Enter the second (0-59): ");
fgets(input,DEBUG);//scanf("%bd", &sec);
sec=atoi(input);
fprintf(DEBUG,"\n\rread %u\n\r",sec);
regb_var.SET=1;// REGB |= 0x80; /* inhibit update while writing to clock */
write_rtc(REGB,(int8)regb_var); //set reg B
write_rtc(CLK_SECS,sec);
write_rtc(CLK_MINS,min);
write_rtc(CLK_HRS,hr);
write_rtc(CLK_DOW,dy);
write_rtc(CLK_DOM,dt);
write_rtc(CLK_MON,mn);
write_rtc(CLK_YR,yr);
write_rtc(CLK_HRS_ALM,0xFF);
write_rtc(CLK_MINS_ALM,0xFF);
write_rtc(CLK_SECS_ALM,0xFF);
regb_var.SET=0;
