Topic: error while verify (Read 2032 times) previous topic - next topic
mohamed_hamdy
when i click on verify this massage display on :avr-g++: CreateProcess: No such file or directory
please need help important case .... i use win 8 64bit and adruino uni R3 & adruino EWR 1.0.3
mohamed_hamdy
cyberbiota
I have been getting the same error for a week now. What is going on?
marcel_sauer
i'm not for sure but above you set "public" thats collored so its not good put // in front of this rule.
hope it will work
MAS3
You're right.
We can't see the top lines in the picture.
But it should start with /*, marking a mulitple line comment.
We do see the */, marking the end of it.
And we see the text is not gray, so IDE is trying to compile this part resulting in the error.
So make sure the top of your blink sketch starts with this /* and you should be good to go.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
marcello.romani
A recurring problem, it seems:
http://arduino.cc/forum/index.php/topic,48557.0.html
mohamed_hamdy
Thanks problem was solved  :D :D :D :D :D :D :D :D :D :D :D
marcello.romani
Could you describe how ? So anyone landing here from a search could benefit from your directions. :)
mohamed_hamdy
use this link : http://arduino.cc/forum/index.php/topic,48557.0.html
